Brake caliper rebuild question
Old Mar 20, 2016 | 10:02 PM
68sting's Avatar
68sting
Default Brake caliper rebuild question
Im rebuilding my calipers and the lip seal must have deteriorated in the bore. I have a black ring that I need to get out. Can I use some 600 grit sand paper to clean up the bores?
Old Mar 21, 2016 | 01:24 AM
Frank_Nesta's Avatar
Frank_Nesta
I am not sure I understand your question. Is the black ring a stain or is it a physical lump of black rubber from the seal? If it is from the seal I would use a knife to scrap the excess. And hone the surface smooth.
Old Mar 21, 2016 | 10:41 AM
68sting's Avatar
68sting
I would say more of a stain. What would you hone it with?
Old Mar 21, 2016 | 10:46 AM
GUSTO14's Avatar
GUSTO14
Have you tried a solvent like lacquer thinner? If that doesn't work, I'd try something like chrome polish before I would go to a sandpaper.
Good luck... GUSTO
Old Mar 21, 2016 | 11:10 AM
Frank_Nesta
I would try the lacquer thinner. If that does not work I would leave it alone.
FYI. This is what a brake cyclinder hone looks like.
https://www.zoro.com/westward-brake-...Q&gclsrc=aw.ds
Old Mar 21, 2016 | 11:18 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Brakes
If you are referring to a rubber seal that is stuck to the bores of the caliper, I have used paint remover. It works effectively and quickly. I follow up with a good clean with soap and water and air dry with compressed air. I next use denatured alcohol with pipe cleaners to clean the passages. Lastly, I dry using compressed air. I assemble using clean Dot 3/4 brake fluid. Good luck. Jerry
Old Mar 21, 2016 | 12:50 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your ring could be where moisture leaked past the seal over the years. A brake hone will clean it up.
Old Mar 22, 2016 | 02:03 AM
68sting's Avatar
68sting
I thought I had read not use a brake hone on SS sleeved calipers. I did see a video that mentioned 600 grit emery cloth. I have a brake hone so that is an option.
Old Mar 22, 2016 | 09:35 AM
redvetracr's Avatar
redvetracr
I would try something like a 3M scotchbrite pad lubricated in a solvent tank before emery cloth
Old Mar 22, 2016 | 10:50 AM
DonnieP73's Avatar
DonnieP73
I used a scotchbrite non-scratch pad and brake fluid to polish my
stainless steel sleeved calipers when I rebuilt them.
Donnie
To Brake caliper rebuild question
