1972 corvette overheating problem.
Old Mar 21, 2016 | 02:53 PM
thelargechic's Avatar
thelargechic
Default 1972 corvette overheating problem.
I'm running a small block 400 .030 over
291 camel humps
Edelbrock performer intake
750 holley
L79 cam with 1.6 rockers
I simply can't figure out what the issue is, it goes from start up to 250 in no time! And I don't want to ruin my engine. I used to have a mechanical fan without a shroud. Figured that was the issue, so after that I installed an electric fan, still the same issue. Lately I've heard about there being an airdam factory? I have a 75 front clip on my 72 (not my doing) do I need a factory air dam?
Old Mar 21, 2016 | 03:25 PM
Uncle Salty's Avatar
Uncle Salty
Did this problem just show up? Did you change anything just prior to the over heating problem arising? How long have you been running this engine in it's current state?
Old Mar 21, 2016 | 03:28 PM
thelargechic
My car started as a project and when we first got everything working it was working just fine. Could let it idle and sit there for 30 min without an issue. It's been ran about 5 times since to see if we fixed the issue. But to no prevail.
Old Mar 21, 2016 | 03:37 PM
homestead's Avatar
homestead
Its not a stuck thermostat is it? Does the radiator get hot as well? I usually drill a 1/16 hole in the thermostat so it bleeds the air out of the system. Just making sure we don't miss anything....
Old Mar 21, 2016 | 03:54 PM
c3_dk's Avatar
c3_dk
What is your timing?
Old Mar 21, 2016 | 04:11 PM
Uncle Salty
Are you going by an accurate gauge? Is it really overheating or are you just seeing high temps on a possibly bad gauge?
Old Mar 21, 2016 | 04:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
All C3s have a chin spoiler to aid cooling, including 75s. If you don't have one on your clip, add it.
Old Mar 21, 2016 | 04:30 PM
thelargechic
I'm seeing high temps on the gauge. And I've already changed the thermostat many times, from 195 to 160 then ran it without a thermostat and still nothing, other than taking longer to get to that temperature.
Old Mar 21, 2016 | 04:39 PM
rcread's Avatar
rcread
Does it overheat at idle, when you are driving it or both?
Old Mar 21, 2016 | 04:41 PM
thelargechic
Never had any issues with it at idle only when driving.
Uncle Salty
Have you verified the current gauge is correct?
Old Mar 21, 2016 | 04:47 PM
SH-60B's Avatar
SH-60B
That's the classic symptom of missing air dam. Put one on and problem solved. I went thru this too.
Old Mar 21, 2016 | 05:38 PM
GUSTO14's Avatar
GUSTO14
Have you had this car on the road at all with this engine in the car?
The '75 front end does draw air from underneath the bumper, so they do have an air dam that directs air up and into the radiator.
Without this the car may in fact overhead on the road, particularly while the engine is under load. Since it really is only effective while moving forward, it shouldn't contribute significantly to the problem you've identified if it only occurs at idle. That's the reason for the above question.
GUSTO
Old Mar 21, 2016 | 05:50 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Make sure your fan shroud has a good surround to it.
Old Mar 21, 2016 | 06:34 PM
rcread's Avatar
rcread
You are missing the hood to radiator support foam seal. That would definitely help. Check to see if you are missing any other seals. All air entering the front end should be going through the radiator. As mentioned above, make sure timing isn't retarded. Make sure your vacuum advance is operating properly.
To 1972 corvette overheating problem.
