I Failed the intake manifold class
Old Mar 24, 2016 | 11:20 PM
forman's Avatar
forman
70 ,, this afternoon i cut the top of a old junk holley i had for parts I put it on the manifold and used modeling clay on the top and had a 1 in ,, i figured If i milled the manifold i would only gain 1/4 of a inch and i really don't think its enough
Old Mar 25, 2016 | 01:00 AM
htown81vette's Avatar
htown81vette
I had a similar issue with my 81 after buying the rpm intake, so I bought a dropped air cleaner, it was actually dropped way more than it should but then I bought spacers and played around with the heights until it fit perfectly. You probably couldn't squeeze a nats *** between the air cleaner and the hood but it fit and without contact. Just thought I would throw my experience out there...
Old Mar 25, 2016 | 01:28 AM
bluedawg's Avatar
bluedawg
Originally Posted by Doug Kraft
At least this didn't happen. Years ago I was walking through one of the base shops where you could work on your cars. A fellow was changing his intake on his 74 from stock to a high rise edelbrock. I asked him if he had checked his hood clearance before doing it and he replied that "the guy at the parts store said it would fit". I said he might want to just set everything on the motor and check before he bolted it all down. He said there was no need to as the guy told him it would fit. I walked away hoping he would check it out but he didn't. Bolted everything down got it ready to go and to prove a point got me to watch him close his hood. Without the air cleaner on it and of course the stud sticking up out of the Q Jet he let the hood drop, more to the point, let it slam down and put a nice hole in it where the air cleaner hold down bolt was.
I've seen that.
Old Mar 25, 2016 | 10:44 AM
drwet's Avatar
drwet
Years ago I put an L88 hood on my '79. I love the way it looks and allowed me to install exactly the carb and manifold package I wanted without having to compromise anything. I solved a bunch of problems, the car runs great, and looks good too. It really is worth considering.
Old Mar 25, 2016 | 11:15 AM
forman's Avatar
forman
Im not changing the hood … Im gonna be looking for a performer rpm ,,I could spend another 150.00 on a no choke center section for my carb but for the same money i could find a good used manifold and solve my problems all together ,, problem solved
Old Mar 25, 2016 | 11:30 AM
ddawson's Avatar
ddawson
?? Choke removal is so you can run a thinner filter correct?
I thought about trying the RPM but when I looked into it I was worried it would be too tall.
Right now with the standard 3" filter, 3/8 spacer needed to clear the linkage and the 1/4 spacer for the heat shield I have just a little more then 1/2".
I tried a 1/2 air cleaner spacer and everything still fit but after a drive you could see the wing nut made contact a few times. I'm using the Repro LS6 intake.
If you click on the last picture you can zoom in and see the spacer and how close the linkage comes to making contact.
Old Mar 25, 2016 | 02:19 PM
htown81vette
Also you can get custom filter heights I believe but I didn't have to go that far to get mine to fit.
Old Mar 25, 2016 | 02:21 PM
htown81vette
Yeah I used just a regular nut instead of the wing nut, it was that close. Also you can saw down the stud to the correct height and use silly puddy to figure out of you have enough clearance. It's that tight but it should fit, might take ALOT of tweaking.
Old Mar 25, 2016 | 02:23 PM
htown81vette
I'm also for keeping the stock hood (mostly for sleeper purposes). I like the aftermarket hoods but don't want to tip anyone off if you know what I mean....cause they might actually think it's fast....and I don't want to get beat
Old Mar 25, 2016 | 02:27 PM
htown81vette
I would have stopped him right there, most (like 80%) of part store guys are lucky to even make it to the store with matching shoes and socks. Half the time I don't even get the right parts. But some do know what they are doing just depends..., I'm not knocking them in general...but I would be always weary...
Old Mar 25, 2016 | 04:27 PM
learje's Avatar
learje
sorry forgot u wanted a couple more pix, thought id postem up here in case anyone else wanted to see what i had to do to get my airgap to fit, once again, my cars a 73 w a stock hood. If anyone shoehorns a tall manifold in id recomend u check and replace your motor mounts first if needed - new ones raised my engine a bit.
hth
lear
Old Mar 31, 2016 | 08:06 AM
forman's Avatar
forman
Thank you ....
Old Mar 31, 2016 | 09:57 AM
  #33
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I see some of you guys are not running stock intake setups, me also. I to was faced with the same clearance issues under the hood and fitting a filter large enough so the engine would have an adequate volume of air. I rejected the ever popular RPM air gap because it was too tall. There are other options out there that may slightly hinder performance or may actually perform better than the air gap/dual plane intakes. I went with a Team G single plane intake. I have a 4" tall air filter on a 1-3/4" drop base. Air flow is not an issue. Loss of low end torque? Not enough loss to alter my decision with a high rise DP intake and its headaches.
Old Mar 31, 2016 | 10:27 AM
  #34
forman's Avatar
forman
I would rather have the stock dual plane then a single that's just my choice ..
Old Mar 31, 2016 | 10:43 AM
  #35
Captain bob's Avatar
Captain bob
Originally Posted by resdoggie
I see some of you guys are not running stock intake setups, me also. I to was faced with the same clearance issues under the hood and fitting a filter large enough air cleaner so the engine would have an adequate volume of air. I rejected the ever popular RPM air gap because it was too tall. There are other options out there that may slightly hinder performance or may actually perform better than the air gap/dual plane intakes. I went with a Team G single plane intake. I have a 4" tall air filter on a 1-3/4" drop base. Air flow is not an issue. Loss of low end torque? Not enough loss to alter my decision with a high rise DP intake and its headaches.
ok my question may help a lot of brothers. correct me if i am wrong the L-88 used a 850 holley if i recall now forgetting big block /small block i have a great hand fitted L-88 hood with 408" sbc can i use the original drop bottom air cleaner from the L-88 then cut hole in responding hole in bottom of hood and elongaded slot in hood at windshield end of hood for fresh air using original L-88 set up with drop bottom and air cleaner sealed against bottom of hood and screen filter in hood cavity. intake manifold is air gap rpm mounted on AFR heads with 750 holley vacuum secondary carb. right now i have at least 2" from top of air cleaner to bottom of L-88 hood with after market drop air cleaner.-------will it work??????????????
Old Mar 31, 2016 | 11:02 AM
  #36
forman's Avatar
forman
Why can't you use one of these
Old Mar 31, 2016 | 11:30 AM
  #37
ddawson's Avatar
ddawson
If this is with the stock BBC hood can you post some pictures please.
To I Failed the intake manifold class
Old Mar 31, 2016 | 06:56 PM
  #38
Captain bob
forman that is exactly what i want with corresponding hole in bottom of L-88 long hood.is that aftermarket like corvette central?
Old Mar 31, 2016 | 07:02 PM
  #39
Captain bob
i have all kinds of room above 2" air cleaner right now with air gap rpm manifold.i hand fitted hood now a perfect gap both sides,front.
Old Mar 31, 2016 | 07:07 PM
  #40
Captain bob
this is the hood
