Door Sill Refurbishment
Through the years, we all may end up with this if an uncaring owner is involved. Seatbelt scratches mostly.
Sure I could buy new, but I want to keep this car as original as possible, and I like the idea of renewing, not scraping.
Can these sills be milled down to a clean smooth surface?
TIA.
Steve
From your pictures it appears the sills have already had the black paint redone at some point.
Since the sill plates are anodized extruded aluminum restoring them requires removing the anodizing, resurfacing them to remove the scratches, and then protecting the new surface in some way.
The process would probably be similar to the one some people use to restore the rocker trim panels.
Regards,
Alan
Regards,
Alan
Yes indeed, I painted the black for just a temporary fix, but of course the scratches remained. I wonder how people resurface. Sanding perhaps?
Much appreciated sir.
Steve
You can't polish the stuff without removing the anodizing. Either chemically (my preferred method) or mechanically (sanding, harder that you would think especially with all the corners and crevices) and if you sand you need to do the entire strip since it will be noticeably different than the original finish
If you strip them, you can file/sand out a lot of the marks but of course some are pretty deep and you'll end up with a wavy mess if you try to smooth out all of them.
Then go to a steel wool/kerosene sanding to even out the finish and get it brighter without making them actually polished
Clean really well and apply a couple of coats of a good clear or semi-gloss clear. This will get it close to the original finish
This might be an area where you put your originals away for someday and pop on a set of repo's.
I've done that, the part about buying a repro and storing the original. The problem is, I'm storing parts that are taking up space, and the car's lost some originality. Sills aren't too pricy, so that's not a problem. I've still got time, so I'll do what you suggested and strip, sand, and finish as described.
Much appreciated.
Steve
The problem M describes…. getting the deepest marks/gouges out of the surface with out the part ending up wavy/lumpy looking... is the same problem that people run into when restoring the rocker trim to the original appearance.
Fortunately the rocker trim is mounted even lower and turned at a slight angle so the lumpiness isn't as obvious as it is on the sill plates.
The original sill plate appearance was very nice but turned out to be very impractical when the car was driven.
Regards,
Alan
For stripping anodize, I find the easiest is crystal draino....outdoors.
Make a little 2x4 wooden frame big enough for your parts to lay in, pace a heavy plastic (heavy duty garbage bag works) over so you have a "pool"
Warm/hot water and a bunch of draino (crystal not the liquid stuff)
move the parts /water around a bit so fresh solution is on the parts
Use an electrical meter and just rest the leads on the part (don't press in with the sharp points as they will go through the coating) check for continuity at different points on the parts to see when the anodize is gone.
Anodize is not conductive so when it's gone the meter will show.
Once it's gone the aluminum is much easier to sand/polish. The anodize is very thin but surprisingly hard
M
Regards,
Alan
M
I'm not sure how much trouble your willing to go through to remove/refurb these. New sills are around 19.00 each.
Willcox
Regarding the final finish on the OP's sills, I strongly suggest taking them to an anodizing facility after they're cleaned up. An alternative would be to have them clear powder coated. Those are the only two ways I know to make the finish last a reasonable amount of time after all this work is done. I occasionally finish electronics panels with clear lacquer when I'm in a hurry, but that would never hold up in this application.
I pulled the video down because I didn't want any liability issues...
But.... I use Sodium Hydroxide (lye), and Sodium carbonate. (soda ash which you can get at a pool supply store or by cooking soda at around 350 degrees for 1/2 hour) with reversed current to my anodes.
The bi-product would be the hydrogen bubbles generated which can lead to some fun to the inspecting individual and the black **** created on the part being cleaned.
Aside from that its a pretty nice tool to have since running it is cheaper than having someone run the compressors and the sand blasters.
Willcox
Willcox
