Frame change
Old Mar 31, 2016 | 11:23 AM
newvettor's Avatar
newvettor
1st Gear
Default Frame change
Will a 74 body fit any other year frame with few modifications? Got a hole in mine and trying to get the best price I can on a replacement since as you all know when I start the frame swap there is going to be a lot of other things I will end up doing as well.
Thank you.
Old Mar 31, 2016 | 11:45 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You should find this helpful...
http://www.71corvette.com/frames.html
...and welcome to the shark tank.
Old Mar 31, 2016 | 01:13 PM
redvetracr's Avatar
redvetracr
I have a frame here from a 74 with a firewall back coupe body still bolted to it if you or anyone else is interested, looks like it has a clean birdcage too.
send a PM...
Old Mar 31, 2016 | 07:17 PM
Ibanez540r's Avatar
Ibanez540r
That is a good start and helps explain changes along the way.
To help you out further, any 74-77 frame will swap to your body no problems. Because 74 had a 1 year only rear bumper crossmember with frame slide impact contraption, going with a 75-77 you will have to also obtain it's impact bumper system if they do not come with the frame. Not really a big deal, just something to keep in mind.
A 78-80 frame will also fit the body fine, but the fuel tank crossmember is different for the bubble back window style cars with larger tank. Some work / fabrication would have to be done to make this frame work for you.
Also, not sure what you have now, but it is nice to find an automatic frame as they have the removable cross member compared to solid for stick cars.
To Frame change
