electric rad fan temperature switch
Old Apr 4, 2016 | 12:52 AM
Rcdizy's Avatar
Rcdizy
Default electric rad fan temperature switch
I believe this controls the electric rad fan.
Would I be correct by assuming it provides ground to the coil side of the relay when it reaches the hot temperature its rated for?
Old Apr 4, 2016 | 07:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Model year? Is your pic taken on the passenger's side of the engine?
Old Apr 4, 2016 | 08:44 AM
Rcdizy's Avatar
Rcdizy
Driver side. It goes to the fan. 1970 but nothing stock about this motor
Old Apr 4, 2016 | 07:29 PM
The13Bats's Avatar
The13Bats
Normally a temp switch for a fan is grounded through the block when the temp is reached and that sends a ground like you said to the ground side of the relay coil the other side of the relay coil to hot lead...the switch doesnt know or care what year car its screwed into, and yeah, looks modded in the pix...
To electric rad fan temperature switch
