LT-1 Spark Plugs
Old Apr 9, 2016 | 01:11 PM
clatgeo's Avatar
clatgeo
Default LT-1 Spark Plugs
My 1970 rebuilt LT-1 engine currently has Delco R45S (extended tip) spark plugs.
Would you keep the extended tip Delco R45S plugs or change them to the regular Delco R45 plugs?
Old Apr 9, 2016 | 03:10 PM
Red Vert 02's Avatar
Red Vert 02
I run the R45S in my L46 with the original LT1 style pistons. No problems. How do your plugs look ? If they are good why change ?
Old Apr 9, 2016 | 03:37 PM
Solid LT1's Avatar
Solid LT1
OEM plugs were R43 so your 2 heat ranges hotter than stock. Back in the good old days w didn't get much mileage out of our R43s so we would go the R44 plugs but, today there are extended tips that should allow a proper heat range plug to survive longer. Do you have to have AC plugs?
Old Apr 9, 2016 | 03:56 PM
fishslayer143's Avatar
fishslayer143
R45 is to hot for 11:1 compression .. OEM was an R43..
babbah's Avatar
babbah
NGK
Old Apr 11, 2016 | 12:05 AM
Barry's70LT1's Avatar
Barry's70LT1
Originally Posted by babbah
NGK
For the past several years I have been using NGK plugs. Their quality is excellent, never had a problem.
The quality of the Delco plugs were terrible, I was forced to look for something else.
Old Apr 11, 2016 | 12:28 AM
babbah's Avatar
babbah
NGK's are quality plugs. I run the Iridium's all my cars including my 67 BB. Well worth the extra bucks!
Old Apr 11, 2016 | 01:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Had bad luck with Delcos starting in the 90s
Switched to autolite never had a bad one
No need for expensive spark plugs
Old Apr 11, 2016 | 02:01 PM
AboveTheLogic's Avatar
AboveTheLogic
What benefits/symptoms are you guys noticing when you say that some plugs were terrible and others were of good quality?
Old Apr 11, 2016 | 05:11 PM
Barry's70LT1
In my case, the last set of Delco plugs I bought had the ground electrodes a different length on each plug as well as not being aligned with the center electrode. The gaps were all off as well.
I had to straighten, file and align all the electrodes. If Delco couldn't assemble the electrodes correctly, then what else was screwed up that you could not see.
I just use the regular NGK plugs, not the expensive versions.
Old Apr 11, 2016 | 05:57 PM
babbah's Avatar
babbah
I've tried them all and the NGK's just seem to perform and last a long time.
To LT-1 Spark Plugs
