BB vs SB Sway bars?
Old Apr 11, 2016 | 11:06 AM
deepstuff's Avatar
deepstuff
Default BB vs SB Sway bars?
Can sway bar presence and size help to ID an original BB car vs a SB carr? How?
Old Apr 11, 2016 | 11:18 AM
MelWff's Avatar
MelWff
The size of the bar and whether or not there is a rear bar. Only problem is they can be added or removed quite easily over the years.
Old Apr 11, 2016 | 11:43 AM
deepstuff's Avatar
deepstuff
I'm looking at a '69 and trying to get as much info as I can. It has a BB but whether its and original BB car or not is in doubt.
Old Apr 11, 2016 | 12:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Not necessarily. It's easy too easy to swap bars.
Old Apr 11, 2016 | 07:25 PM
colesweat's Avatar
colesweat
check the vin #
Old Apr 11, 2016 | 07:28 PM
redvetracr's Avatar
redvetracr
Originally Posted by colesweat
check the vin #
past coupe or convert what does a vin tell you on a 69 ?
Old Apr 12, 2016 | 10:01 PM
BBCorv70's Avatar
BBCorv70
BB cars had a different tach, caps instead of straps fastening the rear half shafts, larger front sway bar, rear sway bar, wider radiator, and a different hood.
You'd need to look up the redline for the particular year/engine. Many people don't swap the tach, a hassle taking the dash apart.
No guarantee, maybe a bit more evidence. All parts can be installed if someone built a BB clone. Is originality important to you? Numbers? If not, does it matter what it started life as? Would 'correct' work for you?
To BB vs SB Sway bars?
