PCV- worth the factory "re connect"
Old Apr 11, 2016 | 10:30 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Default PCV- worth the factory "re connect"
I've been crawling around my '82 and see that the PCV valve has been altered from factory specs by the PO.
I see that the PCV line goes right from the valve cover into the intake manifold. It completely bypasses the solenoid control for the charcoal canister which is properly plugged.
Additionally, the PO disconnected and removed the Air pump and diverter so the emissions controls have been modified. The ERG is in place.
The cars runs very well so I'm hesitant to mess with it, however I'm left wondering if there is an advantage to reconnecting the PCV system so that the charcoal canister operates?
Old Apr 11, 2016 | 11:36 PM
Sunstroked's Avatar
Sunstroked
My thoughts are that the pvc system with charcoal canister does no harm. I retained it when rebuilding my car. If you have the parts, why not hook it up? Many times "back in the day" these items were chucked by over zealous hot rodders.
Old Apr 12, 2016 | 09:39 AM
7T1vette's Avatar
7T1vette
If you hook it back up, make certain to check the type of fuel cap it has on it. When new, the charcoal canister also performed the function of the tank VENT. When folks disconnected them, they usually installed a vented gas cap. For system to work properly, the gas cap must be non-vented.
As mentioned, the only reason to NOT hook it up would be that is doesn't work properly. But, you can hook it up to find out.
The vacuum 'switch' on top of the canister allows the canister to 'purge' vapors back into the fuel charge. That should only occur when the car is not idling. That switch was connected to 'ported' vacuum so there would be no vacuum available at idle condition, and the switch would remain OFF until the throttle was opened during normal running.
Old Apr 12, 2016 | 12:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I re-connected my PVC to the charcoal canister because the engine was stinking up my garage. Now I don't smell anything.
Old Apr 12, 2016 | 08:08 PM
billschroeder5842
Thanks- I bought the PCV (Weird... two port) and will install tonight!
Old Apr 13, 2016 | 12:00 PM
Iron_dog's Avatar
Iron_dog
Can you post some pictures of this PCV valve? Mine has only one connection to the manifold for vacuum, the canister right now is disconnected and the car is stinking...
Old Apr 13, 2016 | 12:12 PM
Sunstroked's Avatar
Sunstroked
Good info 7T1. Thanks and I'll be sure to double check that.
Old Apr 13, 2016 | 02:23 PM
MelWff's Avatar
MelWff
Default Pcv
Neither your post or profile indicate the year of your car. The link below is for a 1982 PCV
https://willcoxcorvette.com/catalogs..._year=32&q=pcv
Old Apr 14, 2016 | 03:32 AM
Iron_dog's Avatar
Iron_dog
Sorry mine is a 74...
Old Apr 14, 2016 | 10:23 AM
MelWff's Avatar
MelWff
On a 1974 the canister is not connected to the PCV. The canister should have a line going to the carburetor.
Old Apr 14, 2016 | 11:11 AM
Iron_dog's Avatar
Iron_dog
Ok thanks that's make sense why my valve has not a T... need to figure now where to connect the canister... thanks
Old Apr 14, 2016 | 11:26 AM
MotorHead's Avatar
MotorHead
That's the PCV I have it has 2 ports, one to the canister and one to manifold vacuum port. I bought an older style canister that only has two ports instead of multiple ports the '80 came with. The other port goes to the fuel tank vent line on the drivers side. No more stinky garage.
Old Apr 14, 2016 | 11:31 AM
Iron_dog's Avatar
Iron_dog
I think that's the one I need for my 74, can you PM the link of the shop? thanks
Old Apr 14, 2016 | 12:00 PM
MotorHead's Avatar
MotorHead
You can get the 2 port PCV at local parts stores and the canister from the Corvette vendors like Wilcox may have one.
Old Apr 16, 2016 | 08:37 PM
billschroeder5842
I pu the PCV back togehter as factory with the two port version.
I checked the engine with the vacuum gauge and the hg increased by 1 (16-17), super steady and the engine idle went up a bit.
I'm wondering if the additional pull from the canister increased the air flow and gave everything an additional bump?
Old Apr 17, 2016 | 03:10 AM
Iron_dog's Avatar
Iron_dog
Thank you!
Old Apr 18, 2016 | 11:51 AM
OldCarBum's Avatar
OldCarBum
I just brought my new 73 home on Saturday. Parked it in the garage and the stink is so bad I pulled the air cleaner off and started looking for any fuel leaks. I found nothing was leaking however I remember reading this post about properly hooking up the canister. My 73 has the 454 and the line leaving the canister runs directly to a T on the PCV valve. From the T on the PCV the line is plugged into the port on the intake manifold in front of and just below the carburetor. The smog pump has been removed and there are several vacuum plugs on the carburetor. On my 73 does the canister line run directly to the carburetor? If so, what vacuum port on the carb? Does the PCV run directly to the intake port in front of and below the carburetor? Thanks Guys...
To PCV- worth the factory "re connect"
