over heated
Old Apr 12, 2016 | 05:01 PM
patrick68's Avatar
patrick68
Default over heated
While restoring the engine compartment of my 68'(52,000 miles) I used those tower clamps. While driving down the freeway the temp began to rise, rapidly !. I was coasting down the off ramp, the gauge was reading 250 deg.
Upon close inspection, the heater core hose had come off. Not sure if I forgot to tighten that one or didn't' get it tight enough.
I replaced the hoses again, new tower clamps and made sure all have been tightened. The first time running the engine, I had a leak above the lower radiator hose connect.
Oil is clean and clear exhaust.
Repositioned the lower hose. Leak reduced to a drip.
Started engine, exhaust is white steam. Oil still clean, no sign of contamination.
Pulled the pump, the inspection plate gasket looked suspect. I think this is where the leak is. Any one have any thoughts on the engine and where I can find this inspection plate gasket?
Old Apr 12, 2016 | 05:06 PM
mikem350's Avatar
mikem350
Normally the pump leaks at the weep hole on the bottom...
Old Apr 12, 2016 | 05:46 PM
SH-60B's Avatar
SH-60B
Steam out the exhaust means coolant finding it's way into the combustion chamber. The first thing I'd suspect is a blown head gasket. It only gets uglier from there, like a cracked head.
What inspection cover / pump? Fuel pump, water pump, oil?
Old Apr 13, 2016 | 01:02 PM
widowmaker221's Avatar
widowmaker221
Definitely a head gasket at least!
Old Apr 13, 2016 | 01:10 PM
patrick68's Avatar
patrick68
Water pump. I can always make a gasket. If you are having the pump rebuilt they can access the pump shaft and seal by removing this plate.
I'll pull all the plugs. I hate tower clamps. Biggest POS ever.
Old Apr 13, 2016 | 01:12 PM
MelWff's Avatar
MelWff
the back water pump gasket should be available at most auto parts stores
http://www.autozone.com/cooling-heat...?checkfit=true
you need to do a compression test
Old Apr 13, 2016 | 01:54 PM
gungatim's Avatar
gungatim
ditto. first indication is over pressurizing the cooling system and blowing off hoses. put a pressure guage on the radiator cap and run the engine. if it runs up past 15 psi quickly you've got a problem...
To over heated
