74 distriubutor
Old Apr 16, 2016 | 01:00 PM
bballboy06's Avatar
bballboy06
Default 74 distriubutor
Will a full size HEI distributor fit against the firewall, and under the shield in 454 74 corvette?
or do i need the small cap?
thanks
Old Apr 16, 2016 | 01:09 PM
Mountainoakie's Avatar
Mountainoakie
thanks
Yes, it'll fit.
Old Apr 16, 2016 | 01:47 PM
69FASTFUN's Avatar
69FASTFUN
thanks
You can use the large cap if you use the shield from a 75 that is when they stared to use HEI or you will have to use the small head to use your stock shield. You could also use Pertronix ignition using your stock distributor to do away with the point and condenser that is what I am using in my 72
To 74 distriubutor
