Header Intake ?
Old Sep 5, 2002 | 12:07 PM
jac1502's Avatar
jac1502
Default Header Intake ?
I need some installation advice, if all goes well I will be installing Dynomax headers and a Elderbrock performer intake this weekend. I know most of you have done these mods already and I have read up on how the passenger header goes through the top and the driver from underneath. And I was hoping for some further advice gaskets, torq specs, ect. Anything thing that might help would be greatly appreciated.
Old Sep 5, 2002 | 12:09 PM
Fevre's Avatar
Fevre
Default Re: Header Intake ? (jac1502)
Pull the z-bar before trying to install driver's side header.
Old Sep 5, 2002 | 12:26 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Header Intake ? (Fevre)
A little off the subject, but about how much does the DynoMax Headers cost?
Old Sep 5, 2002 | 12:28 PM
Fevre's Avatar
Fevre
Default Re: Header Intake ? (OHSIXX)
$220 from Summit. I think you can get them a little cheaper from Jeg's but I got bad customer service from them once so never again.
Old Sep 5, 2002 | 12:31 PM
jac1502's Avatar
jac1502
This is the first time I have ever replaced an intake will i run in to sealing problems?
Old Sep 5, 2002 | 12:34 PM
jac1502's Avatar
jac1502
i could'nt afford the ceramics so i paid $95
Old Sep 5, 2002 | 01:03 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
The manifold bolts should be torqued to 30 ft. lbs. Do you have a diagram with the torque sequence? The headers are easy. You should have no problems there.
Old Sep 5, 2002 | 02:44 PM
jac1502's Avatar
jac1502
Default Re: Header Intake ? (burners)
no i dont know the torque sequence can you explain it or give a reference?
Old Sep 5, 2002 | 02:49 PM
Fevre's Avatar
Fevre
Get a cheap repair manual like Chilton's. It has a bunch of good info but also is very broad so won't have every last detail on each model year.
Old Sep 5, 2002 | 09:40 PM
Johns vette's Avatar
Johns vette
Some people have had problems with the header gaskets leaking because of the bolts loosening up. I put a set of stage 8 bolts on and have had no problems at all. About 32 dollars from Summit. :seeya John
Old Sep 5, 2002 | 10:52 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Header Intake ? (Johns vette)
I Hate Stage 8's true you don't loose the bolts but my gaskets setteled a little and they still leaked.
I know have small head headerbolts. I can get my 1/4 drive ratchet on them and give a nice cranke before a race and I know they are tight:D
Old Sep 6, 2002 | 12:12 AM
MY63Z11's Avatar
MY63Z11
jac1502
I have a Elderbrock performer intake for a small block .Can you tell me the part number of yours I want to make sure the one I have will work on my vette theres a # on the bottom of mine its 2101can you still use the cruise
control.Good luck with it I am planing the same up grades as you
Walt
Old Sep 6, 2002 | 06:47 AM
Disco_Mike's Avatar
Disco_Mike
re: loosening header bolts
i put some copper hi-temp gasket stuff on the header bolts. have no problem with them loosening up.
To Header Intake ?
