Engine mods - EFI conversion
Old Apr 18, 2016 | 11:39 AM
Skybolt's Avatar
Skybolt
Default Engine mods - EFI conversion
So I am want to go with an EFI conversion kit, but i am not sure if I can without having to do a whole lot of other mods as well.
I have an 81' and as mentioned and want to swap out the quadrajet for EFI and run true dual exhaust as well. I also don't know why my car has an O2 sensor when it's not an EFI model ...
If I do this Do I need to remove the ECU as will? and if I do that, how do I get the converter to lockup, replace the converter? That may not be worth doing the upgrade then, or make that a winter project sometime in the future ...
I have searched and read a bunch of post's on this but I am thoroughly confused as to the answer.
Thanks guys.
Old Apr 18, 2016 | 02:24 PM
jim2527's Avatar
jim2527
Yes, you can do it without a whole lot of other mods, but then again, it depends what consider 'a whole lot' of mods.
There are basic throttle body style kits that go on like a carb and complete multi-port kits. Some people do it for a few hundred bucks with scavenged parts while others spend thousands.
Old Apr 18, 2016 | 02:33 PM
Skybolt's Avatar
Skybolt
I guess I should have qualified everything ... Sorry.
I am considering a basic throttle body EFI system, like the Holley one coming out later this year. But that would cause the ECU to not communicate with the Quadrajet and cause a check engine light. I can get an O2 bypass module, but still can't figure out the carb bypass route.
I don't want to remove the ECU if I can help it. I have a TH350 tranny that is solid and I am not ready to replace the torque converter just yet.
Old Apr 19, 2016 | 12:09 PM
Kacyc3's Avatar
Kacyc3
the new efi will replace your carb, o2, and ecu. Did th350 come with a lock up convertor? either way you find the wiring harness for it and either wire it to a toggle switch or buy the b&m vacuum kit and adjust it to your liking.
Old Apr 19, 2016 | 12:42 PM
Skybolt's Avatar
Skybolt
Originally Posted by Kacyc3
... Did th350 come with a lock up convertor? either way you find the wiring harness for it and either wire it to a toggle switch or buy the b&m vacuum kit and adjust it to your liking.
I was under the impression that all '81's with automatic transmissions had lockup converters? It would be great if it didn't, because them I'm basically done. Just put in the wrench time and take a drive!
I was looking at the B&M kit on summit. looks like a nice glove box Item if I do need it? If the lockup is electronic I can keep the ECU and dummy up the O2 sensor. I need to look into this. Thanks for your post.
Old Apr 19, 2016 | 01:11 PM
Skybolt's Avatar
Skybolt
So the spec sheets for an 81' state "TORQUE CONVERTER CLUTCH, 2ND & 3RD GEAR LOCK-UP" but does not state electric or manual?
Does anyone know what type is used? I am guessing manual by cable? is that right?
Sorry for asking dumb questions, I have never played around with an automatic, so I don't know much about them.
Old Apr 19, 2016 | 01:52 PM
Skybolt's Avatar
Skybolt
So I found this in a service manual "In 1980 (except California models), an electrically controlled locking torque convertor was introduced to improve fuel economy. All 1981-82 models have this feature."
So I am going out on a limb here and guessing that the lock up is controlled by a modulator and not the ECU, since 80' doesn't have an ECU or do they?
Old Apr 19, 2016 | 03:43 PM
Skybolt's Avatar
Skybolt
on 1980's cars it is controlled by a few engine factors, in 1981 it is solely the ECU and a controller is needed to achieve lockup at speed.
So I can ditch all of the smog and ECU crap and go with a new HEI dist. and EFI throttle body unit if I use the B&M controller.
Well thanks to google this has been a learning experience today! I hope everyone who reads this has a good laugh, I know I sure would ...
Old Apr 19, 2016 | 05:42 PM
jim2527's Avatar
jim2527
I'm sure you can.... A lot of people have 'ditched everything'. Controlling the lock-up should be least of your worries.
Old Apr 20, 2016 | 02:14 AM
SI67's Avatar
SI67
Thanks guys.
It has an O2 sensor to provide feedback for computer control of the carburetor.
Old Apr 20, 2016 | 09:24 AM
Skybolt's Avatar
Skybolt
Only concerned about the lockup so I don't burn out anything, the rest is a cake walk. Thanks for your reply.
Thanks, I didn't realize that there was rich/lean valve in the mix. I guess I chose poorly with an 81', I didn't realize that this was the first year with an ECM, I thought only 82' was. I still love the car though and very happy I got her.
To Engine mods - EFI conversion
