vacuum advance question
Normally set initial timing with vacuum advance disconnected then hook advance hose to a ported vacuum on carb so as you open throttle and mechanical and vacuum advance timing together up to about 32 to 36 degrees >if you do not have a timing light with a advance **** get a degree tape and stick it to the balancer .
Wes
Looking at on original Factory service manual it say's hook to ported advance .that's the way I was taught GM school years back .
Wes
https://www.corvetteforum.com/forums...long-post.html
BTW, vortec heads wont need more that 34 deg all in.
You need vac advance can connected to full vacuum, not ported. Search the forum as this has been discussed a zillion times.
Vacuum advance controls the curve by adding advance at low load. Idle is low load...
Idle mixtures are lean, requiring more lead.
It's a bit difficult to read your original post. Breaking it up into smaller chunks makes it easier to read, and helps you make your point.
It sounds to me like you base timing is off if it runs rough when you hook up the vacuum advance.
The stock GM method of setting timing and sometimes using ported vacuum sources were for emmissons compliance, not performance.
With your 383....I suspect you'd like a little performance. Use this method for some performance...
-pull vacuum advance line from carb and plug the carb port, also ensure all other vacuum ports on the carb are plugged.
-set engine RPM to 3000
-Adjust timing to 36 degrees by moving the distributor (use a dial back timing light, or a timing tape on the harmonic balancer.)http://www.harborfreight.com/timing-...nce-40963.html
-adjust engine RPM back to idle
-connect vacuum line to a manifold vacuum source at the carb....not a ported vacuum source.
Once this is done you can make a graph on how your MECHANICAL advance comes in, but that is another discussion, get this setup done first.
If your racing then no ported vacuum, use manifold or disconnect it.
Cruising and you want some gas mileage and drivability use the ported. Ive read and reread posts here, other performance sites and racing sites. That is how the majority will tell you to set it up.
I did the following on a 72 lt1 motor solid lifter and 600 cfm carb with headers. Roughly 330 horse. No dyno numbers yet. The performance jump from stock 4* to 36* was ridiculous.
Go buy a good timing light and read the reviews. Craftsman has lousy reviews.. sears, autozone ,summit racing all sell a $90 light that has advance and a built in tach that works great. I lke it cause I dont have to buy the right timing tape, didn't have to set up a seperate tach, and you can see everythng right where your pointing the gun.
For an old school 350 use 36*, newer use 32*- 34* I believe. If you get pinging retard or advance til it goes away, that point is your max
Close off the vacuum.
Set your timing light to 36* advance and work up the throttle to see where it comes in.
Adjust the 36* to match tdc on the timing mark at the point where yours comes in.
It will depend on the distributor. Mine is all in at 2300 rpm.
You can go higher to see if it advances higher but mine didn't change from 2300 to 3000. If you cant reach 36* you may need to disconnect a mechnical advance spring to make it come in easier. This means you need to buy a lighter spring setup
Reset idle and reset timing light to 0 and recnnect the spring.
Check timing at zero at idle. It will be between 12 and 16 probably. Right where your mechanic wants it. This is your new idle timing mark. Reconnect the vacuum advance to the port you want. Mine is on ported and idles down to 900 rpm easily.
This is from information I researched and found and from personal experience on a car for the street not the strip. It will get out of its own way easily.
I would love to feel 400hp in a vette. I know in my GTO it was powerful, and that was a car almost 800lbs heavier.
