Quadrajet Question
Old Apr 21, 2016 | 03:09 PM
TeaEye's Avatar
TeaEye
Default Quadrajet Question
Hi
What does this part do and where does it go?
Old Apr 21, 2016 | 03:33 PM
MelWff's Avatar
MelWff
why do think it is part of a Quadrajet? you found it inside the float bowl or lying on the intake manifold? what year is the carburetor?
Old Apr 21, 2016 | 04:44 PM
PAmotorman's Avatar
PAmotorman
that is used on Rochester 2 barrel carbs to hold in the accelerator pump check ball spring. http://www.newagemetal.com/pages/Old...s20001_jpg.htm item #45
Old Apr 21, 2016 | 04:58 PM
TeaEye's Avatar
TeaEye
Walker lists it as a 4 barrel part. See attachment.
Old Apr 21, 2016 | 05:49 PM
Mountainoakie's Avatar
Mountainoakie
Yep, the same part was used on the older 50's and 60's Rochester two and four barrel carburetors for the same purpose.
Old Apr 21, 2016 | 05:54 PM
TeaEye's Avatar
TeaEye
Thats Good! Now to figure out where it goes?
Old Apr 21, 2016 | 06:02 PM
PAmotorman's Avatar
PAmotorman
I have found them pressed in the Q jet bowl vent on some auto parts rebuilt carbs when I rebuilt them. why they were there I have no idea but I always removed them.
Old Apr 22, 2016 | 11:37 AM
MelWff's Avatar
MelWff
Default where it goes
If you look at this exploded view of a 2G Rochester it's part number 62 part of the accelerator pump check ball mechanism.
http://www.carburetorfactory.com/expvw23.html
I fail to see it in any exploded view of a Quadrajet. The equivalent check ball parts are 32 and 33 of the diagram below
http://www.442.com/tech/rochparts.html
What year or part number is the carburetor?
Old Apr 22, 2016 | 11:43 AM
PAmotorman's Avatar
PAmotorman
it is NOT USED in a Q jet. read my post above. item #32 in your Q jet breakdown is what replaces it
Old Apr 23, 2016 | 02:06 PM
lars's Avatar
lars
It doesn't go anywhere in a Q-Jet. It's a 2-barrel Rochester 2GC accelerator pump ball spring retaining clip. Throw it away.
Lars
Old Apr 23, 2016 | 05:12 PM
TeaEye's Avatar
TeaEye
Thank you all. Like those attachments.....
To Quadrajet Question
