200r4 swap
Old Apr 21, 2016 | 07:32 PM
76yellow's Avatar
76yellow
Default 200r4 swap
Is there any way of putting a 200r4 tranmission in an 80 corvette without buying a new crossmember ?
Old Apr 21, 2016 | 07:36 PM
SH-60B's Avatar
SH-60B
Use the same crossmmember, just unbolt the bracket that holds the TH350 mount. Under it is 2 holes that match the TH2004R mount. You can reuse the same driveshaft, it's the right length.
Old Apr 21, 2016 | 07:45 PM
76yellow's Avatar
76yellow
It appears to be welded on !
Old Apr 21, 2016 | 08:40 PM
fishslayer143's Avatar
fishslayer143
It is welded on 80-82. It does not unbolt .. you can modify it or simply get one from the usual vendors, PTC TCI Bowtie OD, Monster Trans.. Not expensive
To 200r4 swap
