Octane
Old Apr 24, 2016 | 12:44 AM
bugzbunny's Avatar
bugzbunny
Originally Posted by ignatz
Just how far along is your motor? Nobody here has mentioned aluminum heads. Aluminum dissipates heat faster and you can run with higher compression. I assume you would be paying for a head rebuild so that is a $$ trade against new heads.
Don't remember my SBC spec's but the switch to aluminum let me run with 91 here in CA for years and years. Also there is static and dynamic compression which would depend on your cam timing. I am not a motor builder of any kind, just mentioning more topics that may be of value for you to research. And yes, stay away from dished pistons whatever you do, bad experience there, not cheap to unwind that decision.
My LS7 CR is 11:1 and 93 is recommended but I can only get 91. Runs fine, but of course it has knock sensors, so who knows what's going on. But my experience sort of suggests 10.5:1 would be OK.
Stock heads
It's completely torn down now
Old Apr 24, 2016 | 12:48 AM
bugzbunny's Avatar
bugzbunny
Thanks guy's. so my next question would be what the heck did they run back then. Was the Octane higher. I was only 10. so wouldn't know
Old Apr 24, 2016 | 06:59 AM
rdroket's Avatar
rdroket
There were a few stations that sold 100 octane gas. "Clark Super 100".. for one
Old Apr 24, 2016 | 08:54 AM
Revi's Avatar
Revi
Originally Posted by bugzbunny
Stock heads
If you will be running your original heads, you should have them "pocket ported".
Old Apr 24, 2016 | 11:48 AM
ignatz's Avatar
ignatz
Just to update my post to actuals, I went back through my 2002 records. My heads are Pro Topline 72 cc chamber volume, 3.75 stroke, -5 cc flat top pistons, bored 40 over. CR looks to be about 10.3 and as I mentioned 91 is the best gas available here. Pretty safe combo, ran it hard for 10 years, never an issue even on the hottest days, sitting in a line getting ready to run.
