14" triangle air cleaner
Old Apr 22, 2016 | 05:43 PM
keithl1967's Avatar
keithl1967
Default 14" triangle air cleaner
Picked up a 14" triangle air cleaner today for my bone-stock '77
The air cleaner is slightly too tall.
The element is 3 inches tall--I think a 2.25 or 2.5" would work out just fine, but I cannot seem to find anyone that makes a generic triangle filter that is not 3"?
Any suggestions?
Old Apr 22, 2016 | 07:59 PM
Billem's Avatar
Billem
I'd suggest finding a CHEAP 14" round 2-2 1/2" filter and see if that can be reformed to fit the triangle air cleaner. The circumference of a 14" round filter is about the same as a 14" triangle so it might work. (that's why I suggest a CHEAP filter to see if it works) I have actually done this with a different setup and it worked great. Have a great weekend, Bill
Old Apr 22, 2016 | 08:35 PM
keithl1967's Avatar
keithl1967
Originally Posted by Billem
I'd suggest finding a CHEAP 14" round 2-2 1/2" filter and see if that can be reformed to fit the triangle air cleaner. The diameter of a 14" round filter is about the same as a 14" triangle so it might work. (that's why I suggest a CHEAP filter to see if it works) I have actually done this with a different setup and it worked great. Have a great weekend, Bill
I appreciate it--I'll give it a whirl...hopefully I'll be able to get it to work out...
Old Apr 25, 2016 | 10:24 AM
MelWff's Avatar
MelWff
You realize once you go below 3" in height you have the potential to restrict airflow?
Old Apr 26, 2016 | 06:31 PM
keithl1967's Avatar
keithl1967
I thought of that, but this is a stock motor, and does not see much (if any) time in the upper RPM range...airflow will not be an issue...
Old May 1, 2016 | 10:15 AM
keithl1967's Avatar
keithl1967
does anyone know the measurements of the 1969 3X2 air cleaner /element? Did it happen to be 14"? If so, what was the height?
http://www.ecklerscorvette.com/corve...967-1969.html#
part number 25-123861
Old May 2, 2016 | 10:09 PM
Billem's Avatar
Billem
I went ahead and tried resizing my triangle air filter. Didn't turn out too bad. Cut off the top 1/2", placed the uncut rubber boarder in the base and the cut portion under the top. Tightened the top on and there is plenty of clearance. I'm gonna run it for a while and will amend this post if anything bad happens. BTW, any possibility of seeing any of y'all at the Abbeville Spring Festival? Heading up there this weekend. Have a great week, Bill
Old May 2, 2016 | 10:15 PM
Billem's Avatar
Billem
Attachment 47977957Tried posting a couple of pics. Didn't work. Try again.
Old May 3, 2016 | 06:42 PM
keithl1967's Avatar
keithl1967
That looks pretty good...let me know if it holds up...
What did you use to cut the filter/wire mesh?
Old May 3, 2016 | 08:42 PM
Billem's Avatar
Billem
Sharp, heavy duty shears and cut REAL SLOW. Have a wonnerful week, Bill
To 14" triangle air cleaner
