Missing
Old Apr 22, 2016 | 08:51 PM
croaker's Avatar
croaker
Default Missing
Have a 75 with a Quad. After car has run a while it will start cutting out it died on me once. I changed a couple fuel filters and it seems to be getting gas it so far has started back up ok if the coil or module were heating up would this cause this? Where to start troubleshooting so far new cap ,wires, plugs ,fuel pump and s hose which were changed due to failure or leaks
Old Apr 22, 2016 | 09:21 PM
zwede's Avatar
zwede
A bad ignition module or coil can do this.
Old Apr 22, 2016 | 09:26 PM
croaker's Avatar
croaker
I guess replace with a known good unit. Car has 70 k on it prolly original coil and module
Old Apr 22, 2016 | 09:35 PM
Mountainoakie's Avatar
Mountainoakie
"Cutting out" would indicate an intermittent ignition failure and the most likely cause would be a failing ignition module. And when it comes to buying new ignition modules only buy the best brand names because anything cheaper will be a big mistake. Another cause of an ignition failure is a bad connection at the module. You may have to squish the female terminals a bit so the module's male spade terminals plug in nice and firmly; ensuring a good connection.
To Missing
