Dbl Pumper/Tuning - Step In
Old Apr 26, 2016 | 11:49 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Default Dbl Pumper/Tuning - Step In
Greetings all,
I have a 73 coupe with a custom built 383 and TKO-600. Currently have a Dragon Fire HEI with medium springs. Timing is all in @3200.
The carb is a Holley Ultra 750 DP w 4 corner idle. I can get this thing to start, idle and run excellent with the following anomaly;
During medium acceleration, when transitioning from primary to secondary, there is vibration and strange harmonics coming from the motor. Light acceleration and cruising on the highways within the primaries the thing is smooth as glass. Go to WOT, and everything is good. This occurs as the secondaries are transitioning in, blades partially opening, with the initial pump shot. Once I get beyond that it smooths out.
My theory right now is this requires some tuning on the secondaries, but I'm not sure where to start. Would this symptoms indicate too big a pump shot maybe? That is the area I was going to start, but dont want to shoot from the hip.
Could this be more of a timing curve issue? I'm thinking not, as it seems to be more affected by throttle position.
Thanks in advance for thoughts and guidance.
Popular Reply
Apr 28, 2016, 10:06 AM
bashcraft's Avatar
bashcraft
Originally Posted by Mountainoakie
We need to start a double pumper fan club and sell double pumper t-shirts, coffee cups, place mats, and sneakers with the double pumper logo embossed on them. Cool idea, huh?
If you ever get the feeling that you're being ignored, it's because you are.
Old Apr 26, 2016 | 12:45 PM
bluedawg's Avatar
bluedawg
Originally Posted by dosoctaves
Greetings all,
What is the idle at vaccum and what size power valve are you running? Are you running a power valve on the secondaries as well?
Old Apr 26, 2016 | 12:52 PM
ddawson's Avatar
ddawson
Even without a wide band I find this an easy to follow guide with just a Vacuum gauge.
http://www.burtonmachine.com/tech
Old Apr 26, 2016 | 01:27 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Very good article
Old Apr 26, 2016 | 01:37 PM
jotto's Avatar
jotto
Where is TBTR or MO when you need them?
Old Apr 26, 2016 | 02:09 PM
rdroket's Avatar
rdroket
One in the same I believe
Old Apr 26, 2016 | 02:19 PM
MelWff's Avatar
MelWff
If the carburetor is a 76750 list# the power valve is a 6.5 according to Holley. I would start with checking if the secondary pump spring is correctly adjusted. With the throttle held wide open a .020 feeler gauge should be able to be inserted between the pump adjustment screw and the pump arm.
Old Apr 26, 2016 | 02:25 PM
CheezMoe's Avatar
CheezMoe
Thanks gents! I am pretty sure the PV in the primary is 7.5. Vacuum is 15* @ 900 RPM which is what the cam card calls for. Im not sure about the exact PN of the carb nor the component sizes in the secondaries. I'll pull the carb hopefully tomorrow evening and report all sizings, and check the lash on the pump spring as well.
I gave the article a quick read. Unfortunately I'm not set up for wideband at the moment but will try and follow along with the vac gauge. May have to go there before it's over though.
ps: What am I missing with TBTR or MO? Geniuses I take?
Old Apr 26, 2016 | 02:26 PM
fishslayer143's Avatar
fishslayer143
What else is in your motor? It could be that 750 CFM mech sec is too much too soon for it
Old Apr 26, 2016 | 02:56 PM
MelWff's Avatar
MelWff
Default Carburetor number
The list# of the carburetor is stamped on the front of the airhorn
Old Apr 26, 2016 | 05:25 PM
OMF's Avatar
OMF
The first thing I would do is disable the secondarys and confirm everything is working fine on the primarys.
Old Apr 26, 2016 | 06:26 PM
MotorHead's Avatar
MotorHead
[QUOTE=dosoctaves;
ps: What am I missing with TBTR or MO? Geniuses I take?[/QUOTE]
Yeah they are both the same and geniuses
Old Apr 26, 2016 | 11:52 PM
bluedawg's Avatar
bluedawg
If you have a power valve in the secondary circuit, you could plug that and up the jets 10 size's. This works well.
Old Apr 27, 2016 | 03:46 AM
Mountainoakie's Avatar
Mountainoakie
Default Too Much Too Soon
"Too Much Too Soon"......................An excellent phrase every novice needs to learn.
Old Apr 27, 2016 | 08:00 AM
bluedawg's Avatar
bluedawg
It just needs some tuning. This is what you hear when some one can't figure out how to tune the carb to the engine, i know Fish has got it figured out and maybe ya'll say this cause you figure that tuning it to the engine is over the OP's head, but I think that sure there might be better suited carb sizes, but there nothing wrong with a 750 double pumper on a stock 350" as long as it's tuned correctly. I can't recall ever running a secondary power valve and the secondary tip in having a slight stumble and surge is an indication that it's lean when the secondaries start to open, two causes for a double pumper are missing adjusted accelerator pump/wrong size squirter or power valve wrong in size, it's free to check the adjustment, cheap to plug the power valve and jet up and not that expensive to buy an assortment of squirters and experiment to see which responds better.
Old Apr 27, 2016 | 10:37 AM
CheezMoe's Avatar
CheezMoe
This is exactly where I am at and the objective of the thread is to get some idea's on which way to go with these components. I do think the too much too fast thing is relevant, ( but I still think there could be a timing curve factor here.) There is no stumble or bog. I am going to pull the carb tonight, inventory the component sizes and re-adjust. I like to idea to block off the secondaries and run it on primaries so that will be first step after the carb is re-installed.
The motor spec:
350 block 4.040
Scat 9000 3.75
Scat I beam 5.7 rods
Diamond forged flat top piston -5cc
Howards Retrofit Roller .510/234 .530/238
RHS 72/200 Aluminum Heads
Dart dual plane intake
Dragon Fire HEI
Static Compression 10:1
DCR 8:1
Thanks for the input to date.
Old Apr 27, 2016 | 11:02 AM
Mountainoakie
A 750 cfm carburetor is intended to be run on a 427" or 454" and not a little 350". For a 350" you need a 500 to 600 cfm with AVS or vacuum secondaries to prevent "too much too soon".
To Dbl Pumper/Tuning - Step In
Old Apr 27, 2016 | 11:18 AM
CheezMoe's Avatar
CheezMoe
The why did GM put a 780CFM Holley on LT-1's in 1970?
I was warned, and you are officially now ignored noob!
Old Apr 27, 2016 | 11:25 AM
bluedawg's Avatar
bluedawg
Ok too broke, are we going done this road again. Like I said, sure there are better sized carbs, but he's got a 750 double pumper which can be tuned to run good with his engine.
Old Apr 27, 2016 | 11:26 AM
bashcraft's Avatar
bashcraft
My little 350 loves the 800 cfm double pumper that's on it.
