Idle Issue - '72 LT1
Old Apr 26, 2016 | 09:28 PM
rosseich's Avatar
rosseich
Default Idle Issue - '72 LT1
I could use some advice regarding an idle issue on my 1972 Corvette LT1. The engine is completely rebuild, has a solid lifter camshaft, 9.5:1 compression, and the original (fully restored) holley carb; it made 408 HP at 6000 RPM on the dyno. I have about 9,000 miles since completing a frame-off restoration.
The issue is that I can't get the engine to idle smoothly below 1,200 RPM; otherwise the engine runs great and performs extremely well. If I adjust the idle speed via the solenoid, the engine will run at 900 RPM but will slowly die. The idle mixture screws are currently backed out 2-1/2 turns. How many turns is typical? I have read anything from 1-1/2 to 4 turns.
I would appreciate your thoughts.
Thanks.
Old Apr 26, 2016 | 09:46 PM
7t9l82's Avatar
7t9l82
Hook up a vacuum gauge and adjust it to your highest vacuum reading,then re adjust your idle .don't play with the solonoid that's not how you adjust the carburator. Send Lars an e mail and get his carb adjusting papers.
Old Apr 26, 2016 | 09:49 PM
rosseich's Avatar
rosseich
Yes, but I'm unsure that I have it right. Can you clarify the setting?
Old Apr 26, 2016 | 09:50 PM
rosseich's Avatar
rosseich
Yes, but I'm unsure that I have it right. Can you clarify the transfer slot setting?
Old Apr 26, 2016 | 09:57 PM
7t9l82's Avatar
7t9l82
Really you are better off getting Lars to send you his holley papers by email, there is alot of detail and it takes you step by step through it. He doesn't charge anything for them.there is a positivity you have a vacuum leak too. CHeck for that first.
Old Apr 26, 2016 | 10:08 PM
Mountainoakie's Avatar
Mountainoakie
Thanks.
Did you rebuild the Holley? If so did you remember to put new mixture screw seals in the holes where they screw in? If you failed to put new seals in those holes it will suck air along with the fuel. The typical adjustment of those screws is 1-1/4 to 1-1/2 turns out but with leaking seals they'll require 2 to 3 times that much. Does the car have A/C? If so I would suspect the solenoid is used as a fast idle aid when the A/C is ON and the actual method of adjusting the idle speed would be the screw in the base plate.
Old Apr 27, 2016 | 12:55 PM
MelWff's Avatar
MelWff
if you look at the emissions sticker for a 72 LT-1 the solenoid is used to adjust the idle speed not a screw on the base plate. The instructions call for the adjustments to be made with the gas cap removed, the vacuum hose to the distributor removed and plugged. If the engine ran on the dyno without a problem did you forget to connect any vacuum lines when you installed the engine. Why do you have to readjust anything if it ran on the dyno? What transpired between the dyno run and now?
Old Apr 27, 2016 | 09:39 PM
rosseich's Avatar
rosseich
The engine ran well on the dyno but once installed in the car, the idle quality was poor. The '72 Corvette has several vacuum connections which the dyno does not simulate. Who is Lars? How do I contact him to get the information?
Thanks.
Old Apr 27, 2016 | 10:20 PM
63split63's Avatar
63split63
Default Cam ?
408 hp , what cam do you have . Maybe too much cam to have good manners .
Old Apr 27, 2016 | 10:46 PM
riverracer au's Avatar
riverracer au
Thanks.
he's the guru around here for setting up quadrajets and holleys
send email to Lars Grimsrud requesting his holley papers at "V8fastcars@msn.com"
Old Apr 28, 2016 | 12:05 PM
MelWff's Avatar
MelWff
Default Vacuum connections
Thanks.
Can you disconnect and plug those connections and see if you can then correctly adjust the carburetor?
Old Apr 28, 2016 | 07:23 PM
Solid LT1's Avatar
Solid LT1
Sounds like you might have an issue in your cars chassis vacuum system. Isolate the motor by itself and tune it.....then add the brake booster into the system.....then chassis vacuum system.....then isolate wipers from headlamps.......work your way around.....
Old Apr 29, 2016 | 01:49 AM
71coupe's Avatar
71coupe
Is the vacuum advance hooked to the correct port?
To Idle Issue - '72 LT1
