Water Pump
Old Apr 29, 2016 | 10:16 PM
Vettesic's Avatar
Vettesic
Default Water Pump
Water pump started dripping pretty good today. Decieding to replace or get original rebuilt. Are pumps numbered to the car?
Old Apr 30, 2016 | 07:52 AM
Alan 71's Avatar
Alan 71
Hi V,
Water pumps have part numbers and date codes.
The configuration of the casting changed as the years went by too.
For example: the size of the nose of the casting changed as the bearing size increased, reinforcing ribs were added, and a by-pass port 'boss' was added, and then later drilled and plugged.
It really depends how original you want to keep your engine as to if this matters.
Some folks send their pumps to someone who rebuilds them so they get their original back.
Regards,
Alan
Old Apr 30, 2016 | 08:28 AM
Tooch1's Avatar
Tooch1
Yes, as Alan stated original pumps have a part number and date code. If you decide to have your original GM pump rebuilt I would recommend you contact Ron Burke at "Chevy Cool" chevycool@msn.com
When my after market pump went bad on my '73 I contacted Ron to get an original rebuilt GM pump that was correct for my car. Great service and reasonable $$. Very satisfied with the pump when it arrived. I've included a photo so you see the part numbers and date code. Hope this helps.
Regards,
Jim
Old Apr 30, 2016 | 10:06 AM
70Yellowbird's Avatar
70Yellowbird
Since you live on Long Island, you may want to call Arthur Gould Rebuilders in Kings Park. I got mine rebuilt the same day it was dropped off.
http://arthurgouldrebuilders.com
Old Apr 30, 2016 | 11:06 AM
Vettesic's Avatar
Vettesic
Thanks guys as usual. Yesterday I googled rebuilders and Arthur's company came up first. I spoke wth Bob and I will drop off pump mon or tues. $90
Old Apr 30, 2016 | 11:13 AM
Vettesic's Avatar
Vettesic
Regards,
Jim
Jim. Do you know how to decode #s on pump?
Old Apr 30, 2016 | 02:34 PM
Tooch1's Avatar
Tooch1
Yes, the numbers on the left side of my pump is the part number. 330813 for my SB 350. The letter and numbers on the right is the date code: C= March, 3 =3rd, 3 = 73.
The first letter represents the month (January would be A for Ex.) Then the next two (if needed) numbers is the day, and the last number stands for the year 73 in my case.
So, C-3-3 on my pump stands for March 3, 1973.
Hope all this makes sense.
What year is your car?
Jim
Old Apr 30, 2016 | 04:07 PM
Alan 71's Avatar
Alan 71
Hi,
I'll add that the digit below the GM likely indicates the mold used to cast the pump.
Here's the one from my 71.
Regards,
Alan
Old Apr 30, 2016 | 05:29 PM
Vettesic's Avatar
Vettesic
All makes sense now. Mine is E23. #330818 GM 4. From as best as I can see. So non orig. However, I will still opt for rebuild. Got belts, fan, hoses and drained today. Will get pump off tomorrow and drop off mon. Maybe I can see #s better.
To Water Pump
