1968 C3 Big Block Starter Problems
I read somewhere that if the timing was to far advanced that it could have the same result. I did convert the distributer from points to electronic. When the engine was running I advanced the timing to its highest idle, I had not put the timing light on it yet because i cannot start the engine. Before I put the old starter back in to start it could the advanced timing be causing the grinding problem I am having
One thing that came to me i had to loosen the header to get the starter out. when i put the new one in i pull off the coil wire so it wouldn't start with the header loose. The motor seemed to work fine then now that i have exhausted all my options i remember when the coil wire was put back on then is when it started first time then grinding sound on the second try.
Last edited by Abita68-427; May 1, 2016 at 11:04 AM. Reason: I forgot something else
But I am far from an expert on these cars.
with the original starter it could be bad ground,bad battery,to much timming,
bad starter solenoid,no starter sheild when it gets hot. I have always used the
original type starters.
Your zip looks like Abita Springs and I have a 454 68 LeMans blue roadster which is similar to yours.
My 2 cents:
I would try to get it back to close to original conditions and change one thing at a time to pinpoint the problem. So to see if mechanical, you might pull all of the plugs out, ground the coil, or ground the plugs and see if the starter will turn the engine smoothly with no compression. If not, then you figure out why. I think you can also check timing at starter speed anyway by still leaving all of the plugs out, grounding #1 plug and see what your timing light tells you. I would get the idle timing back to zero or a little more, hook it all back up and see if your problem comes back. Then you can advance the timing a little at a time and see if the problem comes back and where. This is what I would do, so maybe this will help. If all this checks out ok, then maybe as above your starter is suffering a heat problem maybe particularly with headers?
Good luck and hope to see your Corvette at the GNOCC or Northshore shows this fall or the Crescent City Boomtown show this May! All great groups!!!
This is the type I am talking about:
Now if you are still with me after reading that ^^^... The fix is to go back to a GM/Hitachi style mini starter with the nose cone, starter gear pinion support etc.. Also the starter gear teeth will be beveled and twisted, making engagement into the flywheel very smooth and quiet, no shims needed.
I went to O Reilys and bought the house brand (Ultima) starter for a 1997 GM 350 Truck($150). The sucker is tiny, it went right in and is quiet with no shims. You do need to use the GM metric shank bolts, get them at your local dealer for $10.
That little starter easily starts my 10-1 compression, 496 with the timing locked out at 31*.
This is what you are looking for:
Notice how the teeth are more beveled on the cone style starter. That really helps with flywheel iregularities.
Here is a good deal on one:
http://www.ebay.com/itm/Chevy-305-35...-/130587673522
