Coolant Sensor Location
Old May 6, 2016 | 08:50 PM
brian76's Avatar
brian76
Default Coolant Sensor Location
I got this new temp sensor for my engine coolant. The problem is- it's 1/4 NPT. The current one is 1/2 NPT mounted in the intake. Do I just drill and tap a new hole, or is there another place to mount it? Thanks
Old May 6, 2016 | 09:17 PM
SH-60B's Avatar
SH-60B
There should be a location in each head, probably plugged right now if your temp sensor isn't in there. IDK the size, but a GM sensor is available in either size.
Old May 6, 2016 | 09:23 PM
brian76's Avatar
brian76
I have AFR 195 Eliminator heads. Do they have these too?
Old May 7, 2016 | 01:33 AM
rcread's Avatar
rcread
I have those heads. Yes, they do. I had to have on of mine drilled and tapped for the larger original sender.
Old May 7, 2016 | 05:20 AM
brian76's Avatar
brian76
Know what I did? I went to Home Depot and got a brass bushing - 1/2 thread on the outside, and 1/4 thread on the inside. Perfect!
Old May 7, 2016 | 09:52 AM
rcread's Avatar
rcread
Yes, one can do that when the temp sender is smaller than the hole.
To Coolant Sensor Location
