1978 random misfiring
Old May 7, 2016 | 12:50 PM
1978BackToLife's Avatar
1978BackToLife
Default 1978 random misfiring
Hey guys, thanks in advance as always for any advice.
Last week I noticed some kind of random in-and-out misfiring. Whenever the car reaches operating temperature, it feels like a cylinder drops out and then comes back in. Never when the car is cold, will be driving along and suddenly it's running rough, then kicks back in fine.
Distributor cap was replaced by mechanic maybe 6 mos ago. Any idea what could cause this? Video attached showing it kick out at the end. It also sounds like some kind of spark knock maybe? Thanks
http://vid3.photobucket.com/albums/y69/bjammerz/Mobile%20Uploads/trim.7A26F30B-DD8E-478D-83BB-28D01033DA88_zpshx13ips5.mp4
Old May 7, 2016 | 01:52 PM
CanadaGrant's Avatar
CanadaGrant
http://vid3.photobucket.com/albums/y...pshx13ips5.mp4
Random misfiring especially after everything has warmed up can be caused by a bad plug wire.
Old May 7, 2016 | 09:15 PM
7T1vette's Avatar
7T1vette
Distributor cap quality could be an issue; but problem is more likely related to ignition system. If you have an electronic ignition system, heat is the enemy of that type system. Module is usually the 'problem'.
If you still have points, the condensor is usually first to go and it starts with erratic miss condition. "Dirty" points can be the issue also; remove and file/sand clean and smooth...retry. (Or replace)
With either type of system, the coil can eventually start to break down and cause miss condition.
If you have some "substitutes" for any of these items, you can "swap and test".
To 1978 random misfiring
