clutch linkage removal
Old May 7, 2016 | 12:51 PM
stephenmsweigart's Avatar
stephenmsweigart
Default clutch linkage removal
I am adding headers and directions say remove clutch linkage...as a newbie is there anything special to this or is it pretty straightforward??
thnx
Old May 7, 2016 | 01:21 PM
Crimson Thunder's Avatar
Crimson Thunder
Take out the bolt that holds the z-bar to the frame and the whole thing comes out.
Old May 7, 2016 | 01:50 PM
Alan 71's Avatar
Alan 71
Hi sw,
Be careful as you take the linkage apart.
There are ball studs, nylon seats, and felt seals at each end, plus a very unusual retainer at the frame mount on the cross-shaft.
It might be wise to keep track of just what's where as you disassemble.
Good Luck!
Regards,
Alan
Here's a picture showing the nut, retainer, and 1 of the seals on the cross-shaft.
Here's the clutch rod. Be sure to get the 2 springs, pin, and clips back in the right places.
Old May 7, 2016 | 05:25 PM
Crimson Thunder
Uh-oh, I'm pretty sure my 1970 doesn't have either of those springs on the clutch rod.What did bubba do now?
Old May 7, 2016 | 05:37 PM
71 Green 454's Avatar
71 Green 454
While you're at it, replace the ball stud. The only time my '71 ever failed me during 40 plus years of ownership was when the ball stud broke at a traffic light.
Old May 7, 2016 | 06:13 PM
Alan 71's Avatar
Alan 71
Hi,
The springs are used to keep the linkage from rattling.
If you're going to replace one of the ball-studs you might as well replace both… there's one at each end of the cross-shaft.
Regards,
Alan
Old May 7, 2016 | 07:50 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Refurbish kits are very reasonable, might as well.
Old May 8, 2016 | 04:18 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Those springs work great. Solved my rattling clutch pedal. Didnt have one spring anywhere on my linkage. I think theres 3 totot on mine
Old May 9, 2016 | 08:01 PM
stephenmsweigart
Default linkage rod
is the purpose of the rod only to act as a pivot point for the clutch?
To clutch linkage removal
