Anybody use Petronix Ignitor Conversion Kit?
Old Sep 7, 2002 | 09:19 AM
70454's Avatar
70454
Default Anybody use Petronix Ignitor Conversion Kit?
I am interested in getting rid of my points set-up and using the Petronix conversion kit to keep the stock look. Anybody have good results from this kit? Any issues with installation? BYW..I've got a 1970 LS5.
Thanks in advance.
Old Sep 7, 2002 | 10:07 AM
Matt Gruber's Avatar
Matt Gruber
Default Re: Anybody use Petronix Ignitor Conversion Kit? (70454)
i use #1181.
be sure to run a fresh coil wire, with the proper ballest resistor, 1 ohm i think.
Denney's Avatar
Denney
I installed the Ignitor in my 66 coupe and love it. Installation is very simple, but make sure you shim the distributor to remove excess end play before installing the ignitor. The ignitor likes a full 12V across it (thus eliminating the ballast resistor used in the stock set up), but if you are running the stock coil it may not hold up to the full 12V very well and thus you may want to replace it with the Pertronix Flamethrower coil. Idle quality improves dramatically. Good luck, I think you will like it.
Old Sep 7, 2002 | 12:38 PM
Matt Gruber
Default Re: Anybody use Petronix Ignitor Conversion Kit? (Denney)
Denny gives good advice. i'm using Acell Super Coil, low ohms, needed ballast.Had to bypass stock + wire.
Follow the instructions.
Old Sep 7, 2002 | 12:42 PM
gdh's Avatar
gdh
Default Re: Anybody use Petronix Ignitor Conversion Kit? (Matt Gruber)
I installed the IgnitorII this summer, with an MSD6AL and Blaster2 coil, everything works great, and I can pull easilly above the 4300 rpm where my points started breaking up. I set the rev limiter to 6500 rpm as it would now pull easily right through to 7000. I have put about 2300 miles or so on this system since last week of July. I have read from others that the Ignitor has had some failures, if mine does next year I will replace it with an MSD Pro Billet tach drive.
[Modified by gdh, 12:12 PM 9/7/2002]
[Modified by gdh, 12:17 PM 9/7/2002]
Old Sep 7, 2002 | 12:57 PM
Larry B.'s Avatar
Larry B.
Default Re: Anybody use Petronix Ignitor Conversion Kit? (gdh)
There was a thread about a lot of failures awhile back. I put points back in for reliability. My 427 pulls strong to 5500 with no problems.
Old Sep 7, 2002 | 02:43 PM
vettfixr's Avatar
vettfixr
I installed one years ago in my 74 and it's still going strong. I wrote a review that you can read here
https://www.corvetteforum.com/review...=221&TopicID=2
It's nice never to have to worry about points again and it's been very reliable for me.
Old Sep 9, 2002 | 12:55 PM
70454's Avatar
70454
Thanks for the replies. Looks like a good project for a weekend.
Old Sep 9, 2002 | 02:48 PM
KJL's Avatar
KJL
I got mine working after some problems. On my 72 the coil voltage (just around 5 volts) was to low to run the unit correctly. I finally ran a wire from the fuse box to provide 12 unswitched volts. Works great now. Pertronix has a new one out which I think they call the Ignitor II. This one will adjust the dwell to increase/maintain spark performance at higher RPMs plus has a auto kill feature so if you leave the key in start it will ground out the system saving itself and the coil from burn out. Costs more though... :rolleyes:
Old Sep 9, 2002 | 03:48 PM
joe58's Avatar
joe58
Default Re: Anybody use Petronix Ignitor Conversion Kit? (KJL)
I have read some complaints on the lower price unit where you have to turn key on then wait a few seconds before starting engine.
Old Sep 9, 2002 | 05:32 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: Anybody use Petronix Ignitor Conversion Kit? (joe58)
I installed the Igniter I, and it failed after about 1200 miles. I then tried the Igniter II, which failed after 500 miles. Now I am using the old points with the Flame Thrower coil, and it runs just as good as with the Igniter(s) actually worked.
Go ahead and give the product a try (it has a warranty), but keep your points in the glove box, and if you ever get a no-start situation, put the old points in first. It will save you a couple frustrating hours.
Old Sep 9, 2002 | 09:19 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: Anybody use Petronix Ignitor Conversion Kit? (Turbo-Jet)
I've had one in four years with an MSD 6A and Blaster coil...over 30,000 miles now.
Old Sep 10, 2002 | 10:55 AM
68shark's Avatar
68shark
Default Re: Anybody use Petronix Ignitor Conversion Kit? (AlwaysWave)
Mine has worked perfectly for the two and a half years or so that I've had it. Only minor complaint is I have the model that you need to turn the ignition on for a few seconds before starting. I use the time to do up my seatbelt!! :cheers:
Old Sep 10, 2002 | 11:26 AM
Alwyn678's Avatar
Alwyn678
Pure Junk I would never use their products......My ignitor II failed very quickly...Now I run a Mallory Dual point tach drive which runs better anyway
Old Sep 10, 2002 | 12:53 PM
Turbo-Jet's Avatar
Turbo-Jet
FYI... http://www.corvettemagazine.com/2000...tion/ignp1.asp
Old Sep 10, 2002 | 12:58 PM
73 LS-4's Avatar
73 LS-4
Consider the Mallory Unilite conversion, I'm running one and has done great so far. I went this route since they seem to be much more reliable according to what I have seen here then the pertronix units. They are more expensive, but I have better piece of mind with one.
:cheers:
Pat Kunz
To Anybody use Petronix Ignitor Conversion Kit?
