knock sensor ???
Old May 17, 2016 | 12:51 PM
hamck's Avatar
hamck
Default knock sensor ???
Hi guys My hearing is shot. I have never heard any pinging in my 76 , but that doesn't mean its not. I have advanced the timing as much as 38* at 2800 rpm but I haven't heard any. Is it possible to rig up a knock sensor with a light on the dash to warn me of the dreaded knock? If so, a P/N of a sensor to use would be very helpful.
Thanks in advance...
Old May 17, 2016 | 01:17 PM
lionelhutz's Avatar
lionelhutz
Well, I've read the sensor and ESC module from a 88-90 GM truck would work to do that. I've never tried it though. The ESC module basically outputs a switched signal to the computer in those trucks meaning it could be used to run a small light bulb instead. Try connecting the light bulb between power and the ESC output terminal.
Old May 17, 2016 | 02:39 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'm away from all my paperwork stuff, but the (5.6 kHz, 100kOhm) sensor and (HKR broadcast code, IIRC) module from an early C4 works well for what you want to do (as I mentioned, I can't tell you at the moment what other models may have similar filtering characteristics). I have this setup on my C4 turbo to help me with recalibrating the fuel and spark tables. An issue to consider is that most knock pulses are so damn fast that it's hard to see any light flash. On my setup I use a pulse stretcher circuit (very easy to make) attached to the ESC module output, feeding a retina burning BA LED. This setup puts out a bright flash that's easily seen while I'm on-track with the car.
The reason I recommend early C4 ESC calibrations is that they have sufficient noise filtering to ignore most valvetrain noise, and also put up with a reasonable amount of piston slap due to worn engines or larger piston/wall clearances.
Old May 17, 2016 | 05:02 PM
hamck's Avatar
hamck
First off, I want to thank you for your response. However, what you are suggesting is waaaay over my head. I was thinking of a sensor, a light and a 12 volt source. I grew up with the breaker points crowd.
Your set up sounds excellent but I'm just not that smart. I could get a hearing aid, but there's things I'd rather not hear nowadays.
Old May 17, 2016 | 05:48 PM
69427's Avatar
69427
Your parts preference (sensor and a light) won't work. The sensor merely outputs a spectrum of audio frequencies representative of all the vibrations of the mechanical parts in the engine. It's the job of the ESC module to filter out the background trash noise (mostly valvetrain), and then output a signal to the ECM that the spark timing should be temporarily backed off.
Give me a little time to take care of some issues keeping me away from the garage, and maybe we can come up with a plan, if you're interested.
Old May 18, 2016 | 08:11 AM
hamck's Avatar
hamck
Thanks When you have time.
Old May 19, 2016 | 04:44 PM
SLVRSHRK's Avatar
SLVRSHRK
I'm interested in this as well, so if you take it to PM, please include me!
Old May 19, 2016 | 09:18 PM
drwet's Avatar
drwet
Its surprising that no one in the aftermarket has come up with a knock sensor kit. We have air-fuel ratio meters. A bolt-on knock sensor seems logical.
Old May 20, 2016 | 01:16 AM
7T1vette's Avatar
7T1vette
You won't get any detonation (spark knock...pinging) just by revving the engine to 2800 rpm. The engine needs to be under LOAD to have significant level of spark knock. Take the car out on the road and you will likely hear spark knock, if the ignition is advanced too far.
Old May 20, 2016 | 05:50 AM
fishslayer143's Avatar
fishslayer143
Its extremely unlikely your stock L48 engine would ping using 89 or 91 octane fuel.. I would not be concerned
Old May 20, 2016 | 03:39 PM
7T1vette's Avatar
7T1vette
I have a '71 with 8.5 compression, also. And it WILL 'ping' if the ignition is advanced too far. If it does, just back it off a few degrees and try it again.
P.S. I wouldn't worry about sticking a 'knock sensor' on your C3 engine...unless a replacement crate engine comes with one already on it.
Old May 20, 2016 | 07:42 PM
hamck's Avatar
hamck
I said ,my timing is set at 38* all in by 2800 rpm . I know that you must have a load on the engine. My problem is hearing it.
Old May 20, 2016 | 09:21 PM
7T1vette's Avatar
7T1vette
If you have [WOT] load on the engine at 2800 rpm and you don't hear any knocking/pinging/pre-detonation....then you don't have any. It would sound like a can of hex nuts rattling around; you would hear it.
Old May 20, 2016 | 09:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Jacobs used to make something like that are they still around or sell out?
Crane take it over?
Old May 21, 2016 | 02:41 PM
69427's Avatar
69427
It's not that simple. Every engine type has different knock frequency and background noise levels. A correct operating system (meaning sensor and module/filter/processor) needs to be calibrated to be able to accurately pick out the knock noise/signal amongst all the engine background noise (think Signal to Noise ratio). It's doable, but it takes either a decent amount of (manual) data acquisition over the entire engine speed range, or a decent amount of software in the module to be able to discern the difference between valvetrain noise, transmission gear induced noise, piston slap, or detonation. Both options are doable, but there's a cost involved and the market for this tool is rather small.
Old May 21, 2016 | 03:07 PM
69427's Avatar
69427
Not necessarily. Knock noise is just like your car stereo. It can be any volume. It's not just either quiet or ear bleeding level.
Also, with louder mufflers or hearing damage, as the OP stated, it's easy to not be able to hear detonation going on.
I still have quite good hearing, thankfully, but that doesn't mean I can always tell if there's knock going on. I can hook an oscilloscope probe to the knock sensor output terminal, and by looking at the screen I can tell exactly when the engine is knocking (even though there's no audible noise). To be heard in the cabin, the knock has to be intense enough/loud enough to drown out the other vehicle noises, and also be of a high enough amplitude to be noticed by our eardrums.
Most newer model cars will knock on occasion, but most drivers will never notice. If the knock control system is correctly tuned/calibrated it will hear any cylinder knock at a small enough audible level (and then adjust the spark advance) that the driver will never know that detonation ever occurred.
Old May 21, 2016 | 04:15 PM
hamck's Avatar
hamck
I would like to thank you for your explanation of how complex system works. With my hearing loss and tinnitus, there's some tones I just don't hear. I guess I need hearing aids. CRAP....I feel so old!
To knock sensor ???
Old May 21, 2016 | 04:57 PM
mikem350's Avatar
mikem350
I would like to try this O-scope trick and see whats happening. My car is VERY loud at WOT. Taking a step further, you could hook up an amplifier (maybe with headphones) and LISTEN to it. A knock sensor works like a rugged microphone....
Wait, why not create a knock app for your smart phone and bolt it to the engine? A little DSP magic and voila
These phones can do amazing things
Old Jun 7, 2016 | 10:25 PM
69427's Avatar
69427
Listening to the sensor output is certainly doable, as you mentioned. It's a useful tool at times. The majority of my dyno time however was spent looking at the noise signals on a scope screen. Something about the visual aspect (you could see and capture the knock noise as it jumps out of the background noise envelope each time) made it more comfortable for me to work with.
Old Jun 7, 2016 | 10:37 PM
Richard454's Avatar
Richard454
Years back - a friend of mine use to race boats- they were very common- he had one for the left AND right motor.
Here's one-
