Idle speeds
Old May 17, 2016 | 02:53 PM
rmgny44's Avatar
rmgny44
Default Idle speeds
What should my '72 L48 w/ auto trans idle at when warm?
In neutral its at 900, stopped in gear 600. Pulling away from a stop I get a slight hesitation and feel like I have to feather it to keep from stalling.
Old May 17, 2016 | 03:34 PM
MelWff's Avatar
MelWff
Idle for your car is 600 in drive with the wheels chocked, not your foot on the pedal. Check the dwell angle and initial timing before trying to adjust the carburetor.
Old May 17, 2016 | 08:01 PM
Peterbuilt's Avatar
Peterbuilt
Is the accelerator pump good?
With the engine off remove the air cleaner, hold the choke open and move the throttle linkage and see if you get two streams of gas squirting into the carb.
To Idle speeds
