What is this wire?
Old May 18, 2016 | 11:45 AM
Phish's Avatar
Phish
3rd Gear
Default What is this wire?
<br > <br >
It's the blue wire hanging below the steering column.
Old May 18, 2016 | 12:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Model year? It may go to the brake pressure differential switch behind it in the first pic.
Old May 18, 2016 | 01:37 PM
Peterbuilt's Avatar
Peterbuilt
It might go to 'A' if you have that switch.
Old May 18, 2016 | 07:28 PM
'75's Avatar
'75
Oil pressure sensor just above the oil filter. 77 uses a blue wire for it.
The thing that makes me think 77 is that there's no shift interlock cable, 77 was the first year without it and 78 and up have a different color wire. Most years use a tan wire for the brake failure light.
Old May 19, 2016 | 10:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1976 blue wire is the oil pressure sender!
Willcox
To What is this wire?
