10in bolts
https://www.vbandp.com/auto-parts/c4...96-detail.html
Dropped it just enough-
DSCN4137 by Richard Hayes, on Flickr
For $15 plus shipping youn can have if you want, you got 1st. dibs. Anyone else after you also. I'm not sure if 8 or9 in.
First couple of autocrosses after this I noticed a very slight rub mark on the inside sidewall of both rear tires from the spring. The next autocross I turned in a bit tighter on a turn and "BAM"- left rear tire lets go. My first though upon looking at the rear tire was I had rolled it off the bead of the rim. Then I looked under the car and saw that the entire sidewall was separated from the rubber bead of the tire. It had completely ripped the sidewall of the tire as if mounted on a lathe.
Check the clearance between the end of the spring and tire carefully. 1" might have worked fine on the street under normal driving conditions, but not for aggressive driving. I switched back to 8" bolts and lowered the rear 1" using another method.
Good luck... GUSTO
A 1/2" Grade 8 bolt has a tensile strength of over 22,000#. That versus the weight of the entire car gives you a 700%+ factor of safety. That versus the highest possible normal load seen by the bolt and you have a well over 2,000% factor of safety. I think you're safe.
Seriously...a coarse thread 1/2" Grade 8 bolt is such ridiculous overkill it's not even worth discussing.
But if it makes you feel any better, those safety factors would increase to 950%+ and 2,800%+ if you used a 9/16" bolt.
My opinion: If you break a 1/2" Grade 8 (or even Grade 5) bolt in this particular application, your car has just been through a nuclear-grade event and this one bolt is probably all that remains of your vehicle.
Also, if the tire goes down on a 15" rim, the head of a 10" bolt will drag on the ground, creating all types of havoc. Probably never going to be an issue (hopefully...), but it is a fact. An 8" bolt is fully 'protected' by the rim in the event of tire failure.
I ran 8" bolts for a long time. I put 10" bolts in my car, played with them for a few months, and put the 8" bolts back.
That's my experience, and it seems to align with Mr. Gusto's experience, so I thought I'd share. I guess my point is: Don't spend a bundle on the bolts you use. I would put the odds at 50/50 that you'll go right back to 8" bolts.
Good luck... GUSTO
I have a VBP 330# spring and 8" bolts. I would like to get it a little lower, but taking the bolts to 0 threads exposed or installing 10"er's is not an option to me. Good luck!
