Rear compartment door rivet installation
Do I have to smash them, or something like that, once in place?.
http://www.mamotorworks.com/Corvette...-door-602461-1
The rivets in your link are known as flat head soft aluminum rivets.
They were set at the factory using a fitting in the end of an air hammer.
If you have access to such a tool you can set them that way too.
If you don't, you can use a small tool similar to a large 'nail set' and a hammer.
In either case the flat end of the rivet must be 'bucked', (firmly held in place), while the rivet is being 'set'. If the access allows it the head of a sledge hammer works well as a 'buck'.
Good Luck!
Regards,
Alan
A rivet set with the tool on an underbody bracket.
