1968 327 damper size ?
Old May 19, 2016 | 05:01 PM
old city's Avatar
old city
Default 1968 327 damper size ?
any body know what size damper they used on a 1968 327-300 hp ? also my damper has 1 (one) mark on the damper is that mark TDC. Thanks for any help.
Old May 19, 2016 | 06:20 PM
Alan 71's Avatar
Alan 71
Hi oc,
I believe the original harmonic damper used on 68 327/300 engines was 6" in diameter and 1-1/4" thick.
I believe the damper surface typically has one line scribed into it to indicate tdc.
Regards,
Alan
Old May 19, 2016 | 08:37 PM
old city's Avatar
old city
Thanks Alan
Old May 20, 2016 | 04:43 PM
old city's Avatar
old city
Default update damper size
found on the net mathematics for sizing you damper. If you need a size for timing tape. measure circumference of your damper . Mine was a little over 21 inches. So I multiplied 6.75 x 3.1416 =21.2. So my damper is 6.75 inches .Many chevy damper were different sizes from 5.75 to 8.0 . 3.1416 is the key to finding the size.
To 1968 327 damper size ?
