Sidepipe Install Question, Need help.
Old Sep 7, 2002 | 03:19 PM
Steve Straus's Avatar
Steve Straus
Default Sidepipe Install Question, Need help.
Hey all, Long time no type! I've been out of the country on business and just generally busy at work after that, so I have had NO time to hang out on here. I miss you all :)
I'm trying to bolt up the pipes to the side of the car, but I'm having a little trouble.
First off, my headers were modified to fit the raised port BBC Canfied heads that I'm using. As a result they stick out to the side a couple of degrees, so there is some resistance moving the pipe up to the side of the car. The guy who did the mod said to get everything bolted up and run it around for a while. The heat from running will make these pipes settle in the right place.
My problem, is that near where the rear T bolt comes out, there's a little lip that makes it so I can BARELY get the rear bushing connected. With the bolt in place I can't get the hanger for the pipe above the bushing.
Does anyone have any suggestions on how to get this installed? Here are a couple of pictures.
Old Sep 7, 2002 | 03:48 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Sidepipe Install Question, Need help. (Steve Straus)
Could you open the door and get to the nut thataway???
Old Sep 7, 2002 | 04:04 PM
JCL's Avatar
JCL
Steve. Long time no hear......... Nice looking baffle. When I do a set of my sidepipes, I don't use the regular sidepipe bracket like yours. I fab up a "Z" bracket so it uses the under the frame t-slot. Alot easier. If you need more info, e-mail me. JCL :yesnod: :yesnod: "Have Baffles.Will Travel"
Old Sep 7, 2002 | 05:26 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: Sidepipe Install Question, Need help. (JCL)
Jim, you've been holding out on me :mad Even if I didn't hear about this earlies, it is still a great suggestion and would make removing pipes much, much easier. Please post or email me too if you please.
Thanks,
Chuck
Old Sep 7, 2002 | 05:49 PM
Steve Straus
427V8: Nope, don't think so. The T stud is going right into the side of the frame.
JCL: you have mail.
Steve
Old Sep 7, 2002 | 06:19 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Before I had my side tubes coated I bent the tabs so that they would use mounts under the frame and there would be no reason to have to cut the rocker panels. So far no problems and work fine. I can get a pic if anyone needs it.
Old Sep 7, 2002 | 06:22 PM
Steve Straus
Default Re: Sidepipe Install Question, Need help. (C3 Shark Tank)
Please post a pic.
Do they sit at the same level as they would if the tabs hadn't been bent?
Do you still use the T studs to connect them?
Steve
Old Sep 7, 2002 | 06:24 PM
C3 Shark Tank
Steve,
They sit at the same level, I used the rear T-hole but for the forward one I drilled a small hole and used a long lag bolt. Let me go out and see if I can get a decent pic....be right back
OK, here ya go. Not a great pic, and the bends don't look great from this angle but from up top you can't tell a thing, pipes are level and sit how they should.
[Modified by C3 Shark Tank, 5:38 PM 9/7/2002]
Old Sep 7, 2002 | 06:48 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Steve, I was beginning to wonder what happened to you!! I am really curious to see how the hedders were modified to fit your heads, so post a pic if you can! Glad to see you are still hanging around!
Old Sep 7, 2002 | 08:01 PM
Steve Straus
Default Re: Sidepipe Install Question, Need help. (7t2vette)
I'll post pictures in a bit. I just finally got my cable modem back up.
The headers had to be cut, bent, massaged, loved and welded back together to fit on the car.
They look like a factory job though, they did top notch work.
Stay tuned.
Steve
Old Sep 7, 2002 | 09:00 PM
Steve Straus
Shark Tank: Thanks for the pictures. I'll see if that's going to work for my setup.
Steve
Old Sep 8, 2002 | 12:23 PM
Steve Straus
Ok, I got the pipe half mounted, with the rear tab. I didn't want to bend the tabs, so I just tried this to see what would happen. I used my cut-off tool to open up that lip that was covering the rear hole. This is so odd, when I have the rear bolt in, the front tab doesn't line up with the hole. Maybe my frame is tweaked.
Should I drill another hole? Will it hurt anything if I just use the rear tab or is it not strong enough?
Here are some pictures.
Here is the pipe, mounted to the car with the rear tab only.
This is the position of the front tab with the rear one mounted.
Here is the rear tab mounted to the frame. ( I know, a bushing is missing, I'm not done yet).
Steve
Old Sep 8, 2002 | 01:18 PM
Chuck Harmon
Steve, I just ground a little off the edge off the piece you showed to to allow the baracket to fit. For what it is worth, my Hooker side pipes don't have a front mounting tab, only the back one and all is fine.
Chuck
Old Sep 8, 2002 | 01:32 PM
Steve Straus
Default Re: Sidepipe Install Question, Need help. (Chuck Harmon)
Thanks Chuck. Good to hear.
Steve
Old Sep 8, 2002 | 05:02 PM
Mr.Gearhead's Avatar
Mr.Gearhead
HEY- THAT IS MY HOOD! haa haa
Hi Steve, sidepipes look great. That car is too nasty to be on the street... your gonna have fun! The hood is perfect for my car, did alittle tweaking and adding some fiberglass when the body goes back on.
-Anthony :cheers:
Old Sep 8, 2002 | 05:35 PM
blacksharkL82's Avatar
blacksharkL82
are you sure you put the right pipe on the right side?
and the left pipe on the left side?
Old Sep 8, 2002 | 08:48 PM
Steve Straus
Default Re: Sidepipe Install Question, Need help. (Mr.Gearhead)
Anthony: Did I put a shot of the hood in there? Glad it fit!
blacksharkL82: yeah, if they were on the other way I'd never be able to put the trim on.
Steve
To Sidepipe Install Question, Need help.
