1978 L-82 Carburetor question
Old May 21, 2016 | 11:58 PM
Indigoblue's Avatar
Indigoblue
Default 1978 L-82 Carburetor question
Not really sure how to explain this..but here goes...Have a 1978 L-82 with original stock 4 barrel carburetor ...car is all stock..all original...all smog components...etc...all vacuum lines appear ok ...when car is running if I rev the motor...there seems like there is a dead spot..as if no gas for a second or two at the very begging ...then engine revs up ok....just seems like always at the begging.... I know nothing about carbs....but had the car in the shop not to long ago and had new wires,plugs,rotor...etc...all changed....any advice on what I might be looking for...???
Don't really want to change the carb...but just in case I do have a new old stock carb still in wrapper and box...and another original carb that has had a show quality restoration done to it by Custom Rebuilt Carburetors LLC...but would like to hold off changing it if its not to hard of a fix
Old May 22, 2016 | 04:32 AM
hunt4cleanair's Avatar
hunt4cleanair
I had some similar responses on my 78 L82 and had the carb rebuilt. Purred nicely afterward.
I would check all your vacuum connections and if you know that the fuel pump is not acting up, suspect the carb. It is not that big of a job to change out the carb to narrow the problem...I'm sure you have done much of this before.
Old May 22, 2016 | 08:59 AM
REELAV8R's Avatar
REELAV8R
Sounds like the accelerator pump.
Take off the air cleaner lid, prop open the choke.
When you actuate the throttle you should see a strong squirt of fuel into the primaries (the area under the propped open choke).
If not or a weak squirt you need to replace the boot on the accelerator pump.
Old May 22, 2016 | 11:53 PM
Indigoblue's Avatar
Indigoblue
Like I said...know nothing about carburetors....
boot on the accelerator pump..??? How do you replace it...???
Old May 23, 2016 | 04:42 AM
SH-60B's Avatar
SH-60B
Check for the squirt of fuel first.
Old May 23, 2016 | 08:57 AM
REELAV8R's Avatar
REELAV8R
Yes, check for the squirt.
I called it a boot on the pump. It can be called a seal or cup as well.
If you've never pulled the top off of this carb is can be daunting the first time.
Get on to youtube and watch some video's.
Here is a good one to start with. You may want to go and find part's one and two to go with this video.
Old May 28, 2016 | 02:37 AM
Indigoblue's Avatar
Indigoblue
ttt
Old Jun 2, 2016 | 01:20 AM
Indigoblue's Avatar
Indigoblue
ttt
Old Jun 2, 2016 | 10:49 AM
Shark Racer's Avatar
Shark Racer
An explanation as to what you're still looking for that induced you to TTT this thread would help others respond.
Old Jun 2, 2016 | 04:54 PM
SH-60B's Avatar
SH-60B
I was also confused by the bump, lol!
Take the lid off the air cleaner and look for a shot of fuel down the carb when you open the throttle before moving on to any thing else. Anything more than that is just throwing darts, you need to verify the accelerator pump is working before any further diagnosis is warranted. Don't worry about replacing it until you know its bad.
To 1978 L-82 Carburetor question
