69 c3 performance limits?
Old May 28, 2016 | 11:42 AM
Bhebert449's Avatar
Bhebert449
Default 69 c3 performance limits?
About to take delivery of my first corvette. It is a 69 L68 tri power coupe. My question pertains to how hard to push the car when driving. I've heard you don't want to exceed 80% of redline. I really want to get a feel for what the car can do but am afraid of damaging the engine. It is a 47 year old car. Thoughts?
Old May 28, 2016 | 12:08 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have a 68 L36, 427/390. The motor was a fresh rebuild to stock specs when I bought it 10 years ago. It is pretty much the same motor as yours except for the carbs. Redline is 5,600 RPM's. I like to jump on it from a roll almost every time I drive it. I rarely exceed 5,000 RPM's. I don't see any benefit to getting any closer to redline. Most of the torque and horsepower is achieved at lower RPM's anyway.
How fresh is your motor?
Old May 28, 2016 | 12:13 PM
Bhebert449's Avatar
Bhebert449
It is the original motor but was rebuilt around 12 years ago and probably has about 6k miles on the rebuild. What should I look out for when driving the car?
Old May 28, 2016 | 12:14 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Why push to more than 100 mph? 47 yr. old anything can happen anytime, build a race car uf you want to push the envelope. Good luck.
Old May 28, 2016 | 12:53 PM
SH-60B's Avatar
SH-60B
As long as everything has been thouroghly inspected and repaired or replaced as neccesary, age is irrelevant. If you are driving a barn find in "as found" condition, you're asking for trouble.
Old May 28, 2016 | 01:35 PM
jim in oregon's Avatar
jim in oregon
Humorously I'D add that unless the German Autobahn is just down the road from your house.
OR you routinely go to the local NHRA eventsat a drag strip..Enjoy the car with it's hp and torque and stay within the limits of the law..and the laws of physics..Serious wrecks or mech failures not on our adgendas..and unless you are under 30 yrs old you probably have nothing to prove..
Drive your Corvette, check all syatems, look, listen..Prove it carefully and thoughtfully..
NEVER let a dodge minivan pass you on the freeway..;and always fill up with 92 octane ethanol free gasoline..Jim.
Old May 28, 2016 | 01:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
6 yr old rebuilt wiht low miles why worry go have fun with it
BBC have strong bottom ends go play
Old May 28, 2016 | 01:44 PM
Bhebert449's Avatar
Bhebert449
Thanks, good advice. I just want to enjoy the car. Not looking to drag race. Car has never been known to run hot according to owner I'm purchasing from. Anything particular to watch and listen for? Oil pressure, strange sounds?
Old May 28, 2016 | 02:18 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
That's a pretty fresh motor as long as it was rebuilt properly. As long as you aren't hearing any strange metallic noises and you are using a proper motor oil you should be able to enjoy your Big Block as it was designed to be enjoyed.
Old May 28, 2016 | 04:26 PM
gkull's Avatar
gkull
I got to drive 69 vettes when they were only a few years old and we drove them like any 16 year old would
They are not that powerful compared to modern cars
Being that old you might experience valve float up around red line
Old May 28, 2016 | 04:27 PM
Haggisbash's Avatar
Haggisbash
If the engine is sound you should have no problem with the occasional blast near the red line. As others have mentioned, making sure you have the correct oil in the engine would be a priority for me and it was well warmed up before I started stepping on it.
Depending on the condition of the rest of the car the engine might be the least of your worries, make sure the steering and brakes are up to the job:-)
Old May 28, 2016 | 04:49 PM
SB64's Avatar
SB64
Default driving
I agree with staying within the limits on the street and I also understand not going to the track. With that said are there any people out there who raced these cars. My 65 fuelie back in the day was a fantastic car for both street and strip. There was nothing other then another vette that was a challenge and at the track when I raced in the 1/8 I would launch at 6k shift at 7k and turn 7.9 100mph. In the 1/4 I ran 12.3's all day long. Once in awhile if you REALLY want to see push it to its limit. You might be surprised. I was!!
Just a thought
RVZIO
Old May 28, 2016 | 04:51 PM
SB64's Avatar
SB64
Default driving
I agree with staying within the limits on the street and I also understand not going to the track. With that said are there any people out there who raced these cars. My 65 fuelie back in the day was a fantastic car for both street and strip. There was nothing other then another vette that was a challenge and at the track when I raced in the 1/8 I would launch at 6k shift at 7k and turn 7.9 100mph. In the 1/4 I ran 12.3's all day long. Once in awhile if you REALLY want to see push it to its limit. You might be surprised. I was!! Just making conversation.
Just a thought
RVZIO
Old May 28, 2016 | 04:55 PM
gerry72's Avatar
gerry72
The redline is the maximum sustained safe engine speed. An engine's redline is established by, 1): the parts durability (forged pistons, forged crank, special connecting rods and special engine blocks for high performance applications are common) and, 2): engine air flow potential (big port and valve heads, big cam, stiffer valve springs, big runner intake, big carburetor and such).
Old May 28, 2016 | 05:09 PM
jim in oregon
Be interesting to know what ALL was done with the engine rebuild..if you don't have that info YET.. IF prevous owner is willing he may have documentation on what HAS and hasn't been attended to or upgraded.'small stuuff like all fluids..hoses, belts, cooling system, tranny, brakes shocks, tires and a host of other necessary and important components go into making a car reliable..predictable within it's limitations and the law and common sense. Again take it slow and watch the gauges and check the fluids..verifying what has or may need attention before you subject the old racegal to anything strenuous..When you have absolute confidence the car will start/stop and run right for a trip of 100 miles at legitimate sustained hiway speeds..Then think about running it thru it's paces..Jim
Old May 28, 2016 | 08:11 PM
The13Bats's Avatar
The13Bats
Yeah doesn't it suck out loud that some kid in a warmed up import can just spank the hell out of the old cars we thought were so bad....
Curious...in 69 new on the bias plys what did the bb's run in the 1320?
Old May 28, 2016 | 08:45 PM
SB64's Avatar
SB64
I know that some of them ran in the mid to high 8's in the 1/8 mile. I can't remember the 1/4. Now the 427/390 for some reason ran in my class but the 435 was in another class. I kind of remember that once they got rolling they would close on me pretty quick though. Always great runs and exciting to have the SB beat the BB. Do a search on under the friday night lights.
RVZIO
To 69 c3 performance limits?
Old May 28, 2016 | 08:46 PM
gerry72's Avatar
gerry72
Depends upon which import (Nissan GT-R???) and which "old car." But in the end, which car is actually more enjoyable to own? Probably not the tarted up Civic, which is like a bellybutton; everyone has one.
Depends upon which '69 BB, but road tests from the day were anywhere from low 13s for the L-88 to mid/high 14s for the lesser 427/390. The 427/435 was a mid 13s car. You can look up the road tests for all the awesome cars of the era.
Old May 28, 2016 | 09:06 PM
mortgageguy's Avatar
mortgageguy
Taking delivery of a 47 yo car, you should ask yourself, are the TA bearings , front wheel bearings, rubber bushings , steering box, ball joints, pivot arms 47 yo? At this point, the capabilities of the engine is only one factor in a sustained high speed run. OTOH, I know for a fact those cars would easily run 140+ mph when new. In 69 , the competition for the Vettes were somewhat limited. In 70, the game changed. Hemi Cudas, Challengers, Boss Mustangs were rolled out.
Old May 28, 2016 | 10:11 PM
The13Bats's Avatar
The13Bats
When I got my first corvette that 72 bb convertible I was young and not too savvy,
The car had a hopped up 454 and stick, the car was in driver condition not pristine, one evening I decided to see how fast it would go, on a little road between Sanford and Smyrna about midnight on a weeknight so it was wicked dark and dead out I pulled over, I wanted to run through the gears, I didn't take off hard as I didn't wanna spin the wheels, in no time I was double the legal limit and creeping past 100, I heard all kinds of noises that just were not right and noticed the hard top only latched at the front was lifting up off the deck in the rear, I wasn't too far past 100 but enough to scare me and back off quickly, on the way home 40-55 seemed so darned slow, I am happy I learned and lived....
