Has anyone been into the engine? Sure looks like a HV pump. If not..I'd test with a mechanical gauge.
If it's accurate I'd change to lower vis oil. I don't mind high pressure..but you don't want it pegged/on the bypass all the time. It should only get super high when at WOT with some RPM.
Someone has installed a different oil pump or maybe installed a higher pressure relief spring in the stock pump. The higher oil pressure isn't really a problem for you. But, it will work the pump harder and use a bit more fuel. Otherwise, just ignore it.
Thanks for input. I don't think anyone has been in the motor. I will try a different viscosity at next oil change. Was worried about something being plugged causing a higher pressure.
I would put a mechanical gauge on it to double check the pressures. I wouldn't assume that the oil pressure is to high without double checking with a good mechanical gauge first.
Also, the sending unit could be wrong or defective if someone replaced it with the wrong one. Or your oil pressure gauge could be off.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine is near 80psi as soon as the revs get above idle. Actually it is probably 70-75psi but if I give it a shot of gas it hits 80psi. This is on a hot day too.
I built engine for the correct oil clearance and I am running the Melling Z28 pump I have used on many engines. The engine has 20k on it now and the high pressure doesn't seem to seem to be causing any problems. I am running 20W50 Brad Penn semi-synthetic oil.
I am a little concerned now after reading above that it could bypass the filter but the engine runs perfect.
As with any electric-based gauge system, it is imperative that the sending unit & gauge are "matched". That is, the sending unit must be designed for a matched gauge. I've seen erroneous readings several times with temp gauges when a replacement sending unit has been installed that is not matched with the gauge.
My opinion ? You're OK. You have a 40 year old gauge that was probably not exactly accurate when new. Check the pressure with a good quality mechanical gauge. (the best quality you can find. good ones are accurate to 2%. )
High oil pressure is not ideal as it puts a lot of stress on the distributor gear, robs horsepower, promotes oil consumption, leaks, and can suck the oil pan dry faster than the oil can drain back to the pan.
As others have stated I would confirm the pressure with a mechanical gauge.
it (a portion) is definitely bypassing the filter, as that is how it is designed, unless you have modified the oiling system (as some do).
stock filter bypass valve is 12-15 psi, so even a stock pump that puts out 35-40 psi is bypassing.
70-80psi is not the correct output for a stock motor with a stock pump, the pump bypass itself would be defective. high volume pumps can have different springs changed out in the pressure valve to increase pressure. the only time I would use a high pressure setup like that is with a race motor setup with very loose clearances for high revving. a situation most street motors never see.
