? on engine pull brackets
Old May 31, 2016 | 07:05 PM
Makonut's Avatar
Makonut
Default ? on engine pull brackets
For a small block, should there be a part # stamped on them?
Old May 31, 2016 | 07:14 PM
hugie82's Avatar
hugie82
Are you talking about the stamped 1/8 sheet metal brackets that bolt to the top of the intake?
Old May 31, 2016 | 07:23 PM
Makonut's Avatar
Makonut
those are the ones.
Old May 31, 2016 | 07:53 PM
Alan 71's Avatar
Alan 71
Hi M,
I believe that while the bb lift brackets were stamped with part numbers the brackets used on sb engines were not stamped.
Regards,
Alan
Old May 31, 2016 | 08:38 PM
62corvette's Avatar
62corvette
Many small block brackets had a stamped omega on it. (Similar to an upside down horseshoe)
To ? on engine pull brackets
