Stripped
Old Jun 7, 2016 | 07:07 AM
manfroni's Avatar
manfroni
Default Stripped
The passenger front ( naturally by the fan shroud) knerels strip in the frame. I would think that the frame is softer than the bolt and just replacing the bolt will not fix the problem. Any ideas?
Old Jun 7, 2016 | 07:48 AM
jnb5101's Avatar
jnb5101
I can't visualize the area, but the easiest route is to rethread the stripped area to a larger size.
Old Jun 7, 2016 | 08:49 AM
SH-60B's Avatar
SH-60B
Are you talking about the upper control arm bolts? If so, new bolts fixed mine. The frame was not stripped, the knurls on the bolts were.
To Stripped
