Poppimg/missing/backfire
Old Jun 8, 2016 | 08:08 AM
stephenmsweigart's Avatar
stephenmsweigart
Default Poppimg/missing/backfire
!970 454 runs good when initially running...after it warms up, it runs like its missing it backfires and breaks up under acceleration. I thought it could be carburation, any ideas??
thanks
steve
Old Jun 8, 2016 | 10:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sounds like timing to me.
Old Jun 8, 2016 | 10:24 AM
mikem350's Avatar
mikem350
What is the history of the car...this a new problem? Could be bad fuel, debris in carb, etc.
I would pull the plugs and look at them. Looking for mis fire on some cylinders, and overall color and condition.
Old Jun 8, 2016 | 10:50 AM
Jeffs82c3's Avatar
Jeffs82c3
Sounds like your choke is stuck in the closed position or your coil is dieing... Not sure if you are running points or not,could need adjusting...
Old Jun 8, 2016 | 01:30 PM
stephenmsweigart
can initial timing be performed w/o finding tdc on cylinder 1?? I basically am working on this by myself and I feel the timing is all jacked up.....there is no vacuum line run from the hei to the carb so most likely that is part of the problem....I was just gonna hook up time light and adj timing to 0 degrees....would that be right??
Old Jun 8, 2016 | 01:45 PM
johnt365's Avatar
johnt365
If it's HEI a bad module can show those symptoms. Many major parts stores can test your old one to verify. Must be removed from car to test.
Old Jun 8, 2016 | 02:38 PM
John 65's Avatar
John 65
Its a longshot...... but by any chance do you have one of those corrected dist caps ?
When they go bad they cause everything you are describing.
Old Jun 8, 2016 | 02:43 PM
dochorsepower's Avatar
dochorsepower
Check ignition wires and distributor cap.
Old Jun 8, 2016 | 04:11 PM
73racevette's Avatar
73racevette
Setting it to 0 degrees would not be correct.
Not sure of the exact number off the top of my head, but something on the order of 34 degrees total timing is in the ball park. That is after distributor advance takes place. I am sure someone here has the exact tolerances or you can google them as well.
0 degrees would be way too retarded to operate correctly in almost any circumstance.
All of this is assuming you are running a standard distributor with a carb setup. If you have a computer setup, then follow those directions as they are likely different.
To Poppimg/missing/backfire
