Wheel Alignment
Old Jun 14, 2016 | 07:29 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Default Wheel Alignment
So, if switching from 225/70/R15 to 255/60/R15, are the front and wheel alignment specifications changed in any way? I noticed that later model C3's show slightly different alignment numbers, but not sure if that is related to the option 255 tires, or other factory changes in the later years?
Old Jun 14, 2016 | 07:44 PM
cagotzmann's Avatar
cagotzmann
What are the numbers you found for each setup?
Old Jun 15, 2016 | 08:09 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Depending on what model year's specs that you are comparing, I could see where they changed, when the cars switched to radial tires. The radials usually have less rolling resistance, therefore, a change in the toe-in setting.
Old Jun 15, 2016 | 03:46 PM
MelWff's Avatar
MelWff
select the alignment spec for your type of driving based on the chart below
https://www.vbandp.com/instructions/...pecs/file.html
Old Jun 16, 2016 | 06:42 AM
Shovels and Vettes
I guess since these specs don't distinguish between the size tires installed, I guess it doesn't matter, but that was my question.
Old Jun 16, 2016 | 07:44 AM
leadfoot4's Avatar
leadfoot4
In all honesty, the 255/60s MIGHT have a tad more rolling resistance than a 225/70, so you might be able to compensate with MAYBE .02* more static toe-in, but I wouldn't worry too much. I would think that your intended driving style, ie. "cruiser" compared to "charger" would be a greater consideration.
To Wheel Alignment
