Rear Hub Runout
Old Jun 15, 2016 | 08:57 PM
ted13b's Avatar
ted13b
Default Rear Hub Runout
I replaced my rear wheel bearings a couple of years ago with Van Steel rebuilts. I have a really bad pulsation from the rear and I see the right rear hub has runout of about .030. Is there any way to correct this without replacing the rear wheel bearing assembly?
Old Jun 15, 2016 | 09:09 PM
'75's Avatar
'75
Is this all run out or is there bearing end play as well? If it is all run out, I would start by removing the rotor and make sure the mating surfaces of the axle flange and rotor are clean and smooth. Then recheck runout, you can re-index the rotor and recheck, although this will block the adjuster hole for the parking brake. There are tapered shims available, although .030" is a lot.
Old Jun 16, 2016 | 06:55 AM
ted13b's Avatar
ted13b
This is runout of the hub, with the rotor removed. I'll be calling Van Steel today to see what they can tell me.
Old Jun 16, 2016 | 11:44 AM
ted13b's Avatar
ted13b
Van Steel says send it back, their web site says limited lifetime warranty, so hopefully it's covered.
Old Jun 16, 2016 | 12:33 PM
jim-81's Avatar
jim-81
Here is a write up I did on using tapered shims - hope it helps.
https://www.corvetteforum.com/forums...out-shims.html
Old Jun 16, 2016 | 06:49 PM
redvetracr's Avatar
redvetracr
how will shims help him?
To Rear Hub Runout
