misaligned alternator fix
Found the curved water pump mounted bracket to be missing a spacer and instead had only a stretched open lock washer in its place. Picture inset.
Found this pried open lock washer where spacer is needed at water pump Alternator bracket mounting. Another correct(?) lock washer is under the bolt head on other side of bracket.
Next discovery is at the alternator itself in the head-mounted bracket. It's a spacer!
At first I thought it was part of the alternator, or like the steel sleeve on the other end where bolt nut threads on.
Upper portion of picture shows extracted spacer, lower shows where it was found.
I had to hammer it loose by using a chisel to wedge in there and knock it out from above, picture shows it from below before doing so.
Hammered the steel sleeve into alternator hole partway to take up the missing space and replaced bolt and nut.
Now alternator is forward where it should have been!
Here you can see the moved spacer and alternator bracket above. Notice rusty sleeve on left and only a small gap other side of bolt head in that bracket. Curved arm bracket now aligns perfectly too, blue arrow shows spacer's new location.
And for a few pictures combined to compare misalignment at upper right, correction made before lower and upper left pictures.
Fixed alternator belt alignment. Upper right shows belt as it looked before this was done (Alt itself was missed).
Pictures showing after fix, and before. The blackened pulleys can be seen where belt rubber had been wearing off, leaving rubber dust everywhere like on fan hub shaft. So yeah, that's not another belt on those; only an illusion.
Fixed shown left side, misaligned on right. Camera was aligned with water pump and crank pulleys both times.
Exactly the reason I was going to say something because I knew it looked like the next misaligned thing to work on! And it was making my fix look strange too.
http://static.speedwaymotors.com/rs/...er-pump-id.jpg
Mine measures at about 6" from engine block to fan mount, maybe just under that if WP side of fan mount and just over on fan side. I can't be more accurate. No doubt the "short" variety instead of "long" anyway.
http://www.alangrovecomponents.com/
Thanks for the tip. I am having belt squealing problems with my belt which could and I think part of it may be due to the alternator bracket. A good thought for a fix.
