Slight miss need advice
Old Jun 18, 2016 | 06:51 PM
hamrad's Avatar
hamrad
Default Slight miss need advice
1973 coupe with newly rebuilt 350. Have a slight miss at idle. With idle set at 800rpm it will surge up to about 850 rpm randomly. When this happens the timing moves about 2 degrees when checking it. Vacuum gauge has 16" fairly steady with a very slight 1/2" random change at idle. I think it also does it cruising around but it is so slight I am not totally sure. Seems to run well, just would like to figure out the issue.
Things I have done so far:
Checked distributor, set end play. Advance is fine and is all in at 2600 rpm. Using 1 black and 1 silver spring from kit.
Rebuilt carb, new float, gaskets etc.
Adjusted valves while hot.
Have changed plugs, wires.
Have not changed points or cap or rotor. They look fairly new.
Any ideas?
Old Jun 18, 2016 | 07:42 PM
diehrd's Avatar
diehrd
Vacuum leak
Old Jun 18, 2016 | 08:52 PM
hamrad's Avatar
hamrad
Originally Posted by diehrd
Vacuum leak
Very well could be. If it is it almost has to be the intake. I eliminated all the vacuum lines except the vacuum advance can. Don't have power brakes, and didn't hook up the headlight system yet.
Old Jun 18, 2016 | 09:31 PM
terry82's Avatar
terry82
disconnect the vac line to vac advance.check idle.if it still goes up and down, check intake.
Old Jun 18, 2016 | 10:37 PM
7T1vette's Avatar
7T1vette
I suspect a problem with the throttle cable. It may not be letting the carb linkage come fully to the [mechanical] stop at idle. Remove the cable from the carb, then 'flick' the carb throttle plates a few times to see if the carb comes back to same RPM at idle. If it does, you have a cable/accelerator pedal problem.
Old Jun 19, 2016 | 01:16 AM
bluedawg's Avatar
bluedawg
Use starting fluid and lightly spray the edges of the intake, base, sides of carb, anywhere their could be potential of a vacuum leak. I say lightly and I mean lightly, a lot if people use propane or carb cleaner but I've found ether gives a more indicative tale tale and whe used lightly works better by showing even the smallest leak, but any open spark will ignite the ether.
Old Jun 19, 2016 | 10:00 AM
REELAV8R's Avatar
REELAV8R
I don't think your timing should be moving this early. Try a stronger spring temporarily and see if the wandering idle goes away.
Too light of a spring may be allowing your timing to advance too early and this will cause it to idle up.
Other thought is that the pivots on the mech advance weights may be worn out allowing some movement early in the rpm range.
Old Jun 19, 2016 | 10:51 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Sometimes a result of a lean condition, I would fatten up the carb
Old Jun 19, 2016 | 01:58 PM
hamrad's Avatar
hamrad
Sprayed starting fluid around intake. No noticeable change.
It has a new performer 2101 intake. I installed it when the engine was rebuilt.
Before I recurved the distributor I put rubber bands on the weights. No change in idle.
Throttle cable has 2 return springs. No problem there.
Carb tuning could be a possibility. The idle mixture screws don't seem to have as much effect on tuning as I thought they should. I can turn the passenger side all the way in and car still idles. The drivers side will stall it out. I can set the idle as low as 400-450 rpm just fine. It acted this way before the carb was rebuilt. I ran a small wire through the idle tubes to make sure they were not blocked.
I am thinking it is either a valve problem or carb problem. The heads were rebuilt with new valves. I am not sure what kind of vacuum reading I would get with a leaky valve??
I have spent days searching the forum for similar problems. I have tried most all the advice I have found. I am at the point now where I might have to take it to someone. Problem is not to many people are very familiar with these older engines.
Thanks for the reply's so far..............
Old Jun 19, 2016 | 02:42 PM
bluedawg's Avatar
bluedawg
The vaccum would be erratic with a leaking valve plus there be other indications such as a back fire through the carb. What springs do you have on the mechanical advance. I use the light springs and with a 950 rpm idle it advances at idle which worked out fine for my situation. But if the timing changes with rpm increase then the question would be is it the rpm change that raises the advance or is it the advance that changes the rpm. What kind of carb do you have and are you running a vacuum advance, if so we're is it plumbed, ported or non ported.
Old Jun 19, 2016 | 08:10 PM
hamrad's Avatar
hamrad
Running vacuum advance, manifold vacuum.
Stock quadrajet carb.
I have a dial back timing light and the timing does not start advancing (mechanical) at idle speed. I changed the vacuum canister with one that is all in at 14" of vacuum.
I'm stumped...........
Old Jun 19, 2016 | 11:22 PM
REELAV8R's Avatar
REELAV8R
Can you explain this?
Old Jun 19, 2016 | 11:38 PM
bluedawg's Avatar
bluedawg
Manual or automatic transmission?
Old Jun 20, 2016 | 07:38 AM
hamrad's Avatar
hamrad
Manual transmission
Old Jun 20, 2016 | 11:01 AM
OMF's Avatar
OMF
With all the things you've tried, i'd be looking at this issue. to me it seems you don't have control of the passenger side idle fuel adjustment.
Old Jun 21, 2016 | 07:45 AM
augiedoggy's Avatar
augiedoggy
I had the same symptoms with both my eddie carb and later my holley... both times the carb was idling off of only one circuit and every now and then some fuel would drip out the other causing the idle to surge... Have you made sure your fuel filters good? Before cleaning the carb well? also I found I needed to switch to a cheaper but better filtering paper elements since the screen ones let garbage past them. this garbage was blocking the idle circuit in my carbs shortly after I cleaned them.
Old Jun 21, 2016 | 07:48 AM
augiedoggy's Avatar
augiedoggy
I agree and am surprised no one else caught this... Although I'll admit I'm not familiar with Qjet carbs.
To Slight miss need advice
