Rear Differential 1978 Vette?
I've also been spending some time with some gear ratio calculators. I think I'll want 4.11 or 4.33, 4.56 is just too crazy. I need to get the car on the road and see if the engine likes being revved up to 6,500rpm and beyond with my new cam before I decide.
you don`t, you pull the cover and look at the flange where the ring gear bolts on, I believe the 4 series case is thicker, you can use a 4 series gear on a 3 series case with a ring gear spacer, 65-79 rear ends used an Eaton case.
After thinking about it some more we decided to just go with 3.73's. With the Roots blower and already having a pretty early torque curve, I think 4.11's would likely just be too unruly without slicks and would blow right through the power band too quickly to really enjoy it. It's already quite torquey down low and with the roots blower which produces boost right away, I think it would probably be impossible to hook up.
If it is the original diff in the car, it is an Eaton. The housing is cast iron. If the housing is aluminum it is a Dana, which never came in a 78 Corvette. Dana'44's were used in 80-82.
The only gears that fit into a corvette are corvette gears. They cost more. There are two types of new gears for a corvette: quality gears and garbage gears. This is not the place to save money. All corvette diffs were built using NDH bearings. They are no longer available. There are several brands of bearings available but if you do not use TimkenUSA bearings you will be rewarded with building it again. And probably replacing the housing.
The new bearings do not set up the same as the NDH. You cannot use the same pinion shim and carrier side shims you took out. This isn't a Camaro. New gears will change the pinion depth .004 just to start with.
You should have a "297" carrier if it is the stock one. There are 4 castings defects that need to be addressed. Also the ring gear flange needs to be trued. New 8620 gears are not as forgiving as the soft OEM gears.
The stock slotted clutches will not handle 400 hp. You need to change to the solids. Your spline teeth are most likely worn out anyway along with the 4 retainers. Does your buddy know how to set up a posi unit? Re-using the stock shims will result in the spider gears hammering everytime you step on and let off the gas. Replace the thrust washers also.
New hardened cross shaft is a must. Along with some decent stub axles. Check the cross shaft bores for "egging".
If you plan on going out and standing on it, you need to consider a steel cap on the left side. Cap stretch is a serious issue with these diffs. Most ring gear failures are caused by cap stretch, not the gears. The stock cast iron cap will stretch like a rubber band with 500hp.
You mentioned putting a truss in. Where? Why? Did you get the .095 or the .134 halfshafts?
-The only gears that fit into a corvette are corvette gears. They cost more.
-There are several brands of bearings available but if you do not use TimkenUSA bearings you will be rewarded with building it again. And probably replacing the housing.
-You should have a "297" carrier if it is the stock one. There are 4 castings defects that need to be addressed. Also the ring gear flange needs to be trued. New 8620 gears are not as forgiving as the soft OEM gears.
-The stock slotted clutches will not handle 400 hp. You need to change to the solids.
-Re-using the stock shims will result in the spider gears hammering everytime you step on and let off the gas. Replace the thrust washers also.
-New hardened cross shaft is a must. Along with some decent stub axles. Check the cross shaft bores for "egging".
-If you plan on going out and standing on it, you need to consider a steel cap on the left side. Cap stretch is a serious issue with these diffs. Most ring gear failures are caused by cap stretch, not the gears. The stock cast iron cap will stretch like a rubber band with 500hp.
Sounds like there are a lot of very specific needs to be addressed. Going to have somewhwere around 500HP and I'm guessing that all this stuff needs to be addressed even for that much power?
I am not sure of the thickness of the halfshafts. I ordered the Dragvette 3" balanced ones. I'll have to see if I can track down how thick they are as I don't remember seeing that.
With all this info I'm thinking it might be easier/cheaper to just buy one already complete as opposed to dealing with everything. Any opinions on the Duntov Motors ones or do you have any other suggestions? I seem to remember that maybe you rebuild them from other threads? I've dropped a ton of cash into the build already and am trying to keep costs down as much as possible, but I certainly don't want to have to spend more in 6 months because it's not done right now.
79 Vette with 388 stroker, just under 500hp and my engine builder said to look for a set up that can handle over 500 torq, with like 390 gears. Currently have stock rear, 700R4 and 3:55 gear ratio, automatic.
Any advice on what companies I should be dealing with to get a setup that is right for my vehicle would greatly be appreciated.
Thank yoiu,
Kevin
They are the performance version and would probably work for you. I am doing a 12 bolt conversion and will not be using them. I also have a polished 10 bolt differential case that was the original in my housing. You can send pm if interested and I would also recommend you give Traccdog2 a call.
The 700r4 has 3.06 1st gear combined with a 3 series gear will give great off the line acceleration.
Thank yoiu,
Kevin
The big question here is how do you plan on driving it? Ever plan on putting slicks on?
Mike
Thank yoiu,
Kevin
Any ideas?
Any ideas?
