I'm rebuilding my rear differential and throwing in some new gears while I'm at. Hoping to go with 4.11's. I'm having some trouble tracking down exactly which rear diff is used.
I've found ring and pinion kits for the vette specifically, but they're considerably more expensive than non vette gears, so trying to track down the details so I can order a less expensive set.
I thought it was a 10 bolt Dana 44, but after doing some more research it looks like maybe that was only on 80's and newer?
I have a 1978, auto trans, 350 L48, (originally a California sold car). Any ideas on the exact specs or where I could find them? Thanks in advance for your help!
My understanding is that for a '78-'79 C3, 3.90 is the shortest gear that will fit in the stock housing. I'll be following this thread, if you come across anything interesting with alternative sources of gears/etc, I'd love to know about it. My local driveline shop wants close to $800 to regear my diff to 3.90, and that is if it is already removed from the car.
The diff casing, the part that the ring gear bolts to, is different for the 4.11 and 4.55 ratios as the ring gear is a bigger diameter so depending on the ratio you have now you may need a new casing as well, I am going from a 4.55 to a 3.55 so went for an Auburn unit from JT transmissions and 3.55 crown wheel and pinion set, they also supplied a fitting kit with all the bearings seals etc
The 4.55 I have in mine at present will be available if you're interested but I'm not planning to change it out just yet as I'd rather spend time driving than under it!
4.11 gears in a street car with no overdrive transmission is a mistake, you will quickly see if you get on the INTERSTATE HYWAY..... 3.73 would be a much better choice
Couldn't agree more which is why I'm changing my 4.55 out and going 3.55 and considering a 5 speed TKO 600 conversion if it's still too busy on the open road. It's like driving round in second gear at the moment!!
Graham
Yes, I understand that. I have a 700R4 overdrive, sorry thought I mentioned that. I've run all the calcs and am comfortable with a 4.11 and where my RPM's would be. It's an around town street/weekend fun car that will also be used for 1/4 occasionally as well. I'm not concerned about mileage and would rather have the fun factor of a 4.11 if I can get away with it.
Yeah, so most of the gears I've found specifically for corvette only go up to like a 3.73, but I'm not sure if that's because you can't fit a 4.11 in a 3 series carrier or if they only go up to a 3.73 because they're assuming that you would still have a TH350 non-OD transmission in the car and they're just quoting stock parts.
I found a 4.11 that supposedly can fit in a 3 series carrier (which I believe is what the stock diff has) from Duntov Motors, but I'm not positive if it will fit. I'm gonna call Duntov and see what they have to say and we're pulling apart the diff to see if we can get any usable numbers or info from the carrier that tells us exactly what we're working with.
Does anyone know if a 78 has a Dana 44? I know it's a 10 bolt and I thought it was a Dana 44, but not positive.
Graham
Luckily I have a 700R4 so I think I'll be fine on the highway. It will be interesting though with the already torquey 355, the new blower sticking out the hood, AND the 4.11's Not sure I'm going to be able to hook up very well, but want to stick with street tires as I'm not ready to throw a 12 bolt in just yet and from everything I've seen that'll be the only thing holding the rear together haha.
We are rebuilding the diff, got new hardened end caps to replace the ****** ubolt straps, and might do a few other things to keep the rear a little sturdier (maybe weld up a truss?). Just got done rebuilding the suspension with a VBP street and slalom kit and all poly bushings as well. Between all that, the upgraded/rebuilt brakes, the new Borgeson unit, the fitech fuel injection, the already installed but fresh motor/700R4 trans, and soon to be new interior, it's basically gonna be a whole new car lol.
I'm kicking myself a bit because last year I had my rear end rebuilt by a local driveline shop for about $1300 including a replacement carrier because mine was cracked. At the time I didn't foresee a T56 swap in my future. Now they want almost $800 to re-gear it. I almost want to just save my pennies and pick up a $1499 unit, then I guess maybe sell my rebuilt unit with its 3.36 gears? Not sure which way I'll come ahead. I wish I had a friend who knew how to set gears properly, the gear sets are under $400.
I'm trying to find the online catalog where I saw gear sets available and for the sets that were numerically higher than 3.90 there was a caveat, still looking.
Yeah, I hear ya on not wanting to have to redo stuff, that always sucks! That's why I'm dealing with it now. We already have the whole rear of the car torn out for a new EFI gas tank and suspension rebuild so of course the "while I'm at it" disease kicked in haha. I'd rather just do everything right this one time instead of having to go back and redo it all again later.
Luckily my brother is a mechanic and has worked with differentials/gearing so he's helping me do it. I'm sure I'd pay an arm and a leg to a shop. I have also considered just upgrading the whole differential, but I don't really want to shell out the money for a 12 bolt conversion right now and I am likely only going to have around 500 horsepower, so I think a rebuilt stock one should be alright. I'm upgrading to new 3 inch halfshafts and doing some other stuff to strengthen back there, but I'm hoping I can get by with the rebuilt 10 bolt for a while.
I'm hoping that I like the T56 with the 3.36 gears enough to not really want to regear right away and keep it as an option later when I want some quicker acceleration.
Tom's differentials makes a 4.11 thick gear that will fit a 3 series carrier.
Thanks Crimson Thunder, it seems that's what we narrowed it down to as well. We made a few calls and it looks like it is in fact a Dana 44 and the 4.11 thick gear should work fine in my carrier. I found a ring and pinion set for considerably cheaper on Summit by SVL drivetrain. It seems like anywhere you find the same thing specifically labeled for a "corvette" (which isn't necessary) they're 2-4x the price.
Not sure if anybody's had experience with SVL drivetrain parts, but I'm not really into paying more just because a part is marketed for a corvette. SVL has a 50,000 mile/6 mo warranty on their parts and I can't find any bad reviews on them, though there's no positive reviews on Summit for them either. Any opinions on if it's necessary to spend more on a ring and pinion set?
The only crappy thing is I figured out my vette apparently has 3.55 gears in it now so it won't be as big of a jump as I thought it would be to 4.11's!!! I guess it was ordered special with 3.55's as I haven't seen any info on 78 Auto's typically having 3.55's.
So now I'm reading that there are 3 series and 4 series carriers, what's the difference and how do you ID them from the outside?
I haven't found exactly how to identify the 3 vs 4 series carrier, but from everything I've read anything stock under 3.90 is gonna be in a 3 series and above will be 4 series. Like Crimson Thunder said, looks like you can just get a thicker ring to run a 4.11 or 4.56 in a 3 series.
Speaking of that, anybody got 4.56 gears in a street car lol?!?!?! I'm tempted.... but I'm thinking a 4.11 mated with the new blower should be enough to keep a smile on my face and not too crazy for the street. I mean I do have a .7 overdrive ratio so I guess I COULD run more, but probably not the best for a street car right? Talk me out of it...
