C3 crankcase ventilation vacuum pump smog pump
1974, custom 355 motor, serpentine conversion. (I have an aggressive cam compcam 12-602-4, but the lack-of-vacuum-for brakes-&-headlights- question will be the subject of a different thread.)
Application: resto-mod, (really) spirited driving, occasional track time.
I have the option of keeping the smog pump from the 92 caprice donor car and re purposing it as a vacuum pump for the crank case. This is just an idea based on cursory research. Is there any benefit to putting effort into vacuum motor (converted smog pump) on a gen1 sbc motor for crankcase ventilation?
Cleaner crank case oil
Moisture removed
Engine parts stay cleaner.
More hp from motor because the blow by gasses are not being pushed around under the pistons on the down stroke.
I see it as win / win .. if your only worried about cost then it is not win / win from that perspective.
Moisture removed
getting to the cost/benefit ratio here, with race motors in certain circumstances, the benefits may outweight the costs, more than slightly. with the OP's motor, I doubt that is the case. can it hurt? no, but is it worth it? only the OP can decide...
Admittedly, it's overkill for my application. I'm probably going to end up in the 400+/- hp range at the crank with this build. But I have the parts and without much modification effort, i can make something work. (I get pure joy out of tinkering with stuff like this.) I can't answer how much hp/moisture removed/engine seals life extended/oil leaks prevented/ etc.
Whatever my results are, i'll post 'em.
-Overkill-Phil
And normally is a compromise , all that crap gets re-burned back into the combustion cycle. And as i mentioned if you could see what drains out of the catch can you would be sorta stunned. I sure was the first time I saw one drained.
And yes cost can be an issue however as creative as people are it can also be cheap. I chose a mechanical system from aerospace components
PCV system uses negligible energy...and it's energy that the engine CAN'T turn into usable torque. It's simple, inexpensive and WORKS.
But, as always, do what your 'heart' tells you to do.....
Dont come at me with I must be smoking something
Simply placing the crank case under a vacuum yields serious benefits in ring seal and eliminating crank case pressure that your pistons are pushing through on every down stroke.
I do invite you to show us that in no way can a belt driven pump FREE up hp your engine is losing with out one and a PCV works as effectively as a pump does because it uses "negligible energy"
So come back with facts and leave out your sarcasm
do what you want, it really can't hurt, and some engine designs it certainly helps, but for the average pre-90's motor it is overkill...the problem with DI motors is that the vapors hit the valves which do not have any fuel to wash them off and cool them so the crud gets cooked on due to the injection being in the cylinder, not the intake. a normal induction system does not have that problem. those engines require valve tear down every 40-50k miles...a stock small block goes 100k or more with out needing that with stock PCV.
Pistons move up and down. Any gain from the down-moving pistons would be negated by the UP-moving pistons. {you gotta be kidding me}
So you are dead right I am wrong a VACUUM pump does nothing ..
It is as you stated "like a wind mill on the roof of a car" ..
With the vacuum pump you are not drawing an actual vacuum in the crank case. The pressure in the crank case is likely not going to fall below atmospheric pressure without a really good pump.
What you are doing is evacuating the pressure created by the blowby from the rings. At best you are eliminating pressure created in the crank case, maybe drawing it slightly below atmospheric pressure, in many cases probably only reducing it to some degree.
At low RPM's and small throttle openings this is effectively done by a PCV through the vacuum provided by the intake manifold.
Consider high RPM/ large throttle openings However.Manifold vacuum drops to nil at that point. Thus the pressure in the crank case has to be pushed out, pressurizing the engine. This significantly increases windage losses and potential ring seal unseating leading to more power loss.
In addition with the PCV all that contamination is still being ingested by the intake further reducing power due to intake charge contamination.
Diehard has a valid point. I believe that you could and most likely do see a significant power improvement over a PCV arrangement.
In the OP's case I would add a catch can on the recovery side and an adjustable valve on the suction side to be able to vary the amount of vacuum to the engine.
Exhaust evacuation seems the simplest solution, but with little control over the level of vacuum and no control over the waste products from the crank case. Although I suppose you could put a catch can between the valve cover and the exhaust evacuation port.
About time someone added knowledge to this topic. I felt like I was falling in a dream that was never going to end.
But hey, this moving air (and oil mist) just goes to the opposite cylinder and pushes it up, right? Everything cancels out, right? Um, No. These are Vee engines, not flat boxer engines. There's no straight path from one downward moving piston to the corresponding upward moving piston (due to balance issues, I don't recall seeing this ideal scenario in boxer engines either). Also, the crankshaft is in the pathway between opposite banks, screwing up the "easy" movement of air (and mist) mass between cylinders. There's also a wall friction/obstruction issue reducing the efficiency of pumping air around in the crankcase.
All in all it's a power waster moving a lot of air mass in unproductive ways. Reducing the mass of air constantly being accelerated and decelerated should result in a net power increase at the crank/flywheel, depending on the efficiency/power requirement of the evacuating pump.
