Headers and A/C
Old Sep 9, 2002 | 07:12 PM
1970 Dave's Avatar
1970 Dave
Default Headers and A/C
Is it worth the pain with brackets and such?
SEMPER FI--1970 Dave
Old Sep 9, 2002 | 07:19 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Headers and A/C (1970 Dave)
I gotta know too! So, same question? :confused:
Old Sep 9, 2002 | 08:20 PM
joevette57's Avatar
joevette57
Default Re: Headers and A/C (OHSIXX)
You need to order the A/C compressor bracket. Best place to start is whoever manufactured your headers. The installation is not that difficult. I have headers on my 70 BB and the compressor fits perfectly and the a/c works very well!
Old Sep 9, 2002 | 08:46 PM
74Coupe's Avatar
74Coupe
As stated above you will need the bracket. I got my Dynomax Ceramic Coated Headers and the A/C compressor mounting bracket from Summit.
Old Sep 9, 2002 | 09:12 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
You can also make your stock mounting bracket work as well. It takes some clearance grinding and making of two spacers.
Old Sep 9, 2002 | 09:14 PM
vettfixr's Avatar
vettfixr
Default Re: Headers and A/C (74Coupe)
I did the same thing. Fits perfect with no problems.
Old Sep 9, 2002 | 11:12 PM
s79vette's Avatar
s79vette
I only had to add a spacer to mount bracket. I made it out of a piece of 3/8th stainless pipe and got the correct
length bolt to fit, about 2 inches longer. Turned out great. The pipe is about 2 inches long, ie; width of old
manifold. Steve
Old Sep 9, 2002 | 11:22 PM
Jvette73's Avatar
Jvette73
Default Re: Headers and A/C (s79vette)
Its worth it. Yur better off modifying yur existing a/c bracket. My Dynomax headers came with inst which described basically how. Some grinding to clear the #2 header tube. Then some spacers or stacked washers to make up the difference in the thickness between the stock iron manifold and the header flange. The aftermarket a/c brackets are pretty much junk and are prone to cracking. I would avoid them if at all possible.
To Headers and A/C
