How much caliper clearance is needed??
Old Jun 29, 2016 | 07:33 PM
rajin cajin's Avatar
rajin cajin
Default How much caliper clearance is needed??
Ordered Billet Specialties street lites for the 72. Tell the guy they are going on a 72. I throw them on and have about a dimes clearance between the rim and brake caliper. Figured I'd throw a thin spacer on as I have absolutely no confidence that a dimes clearance is enough. Any thoughts on spacer thickness??
Old Jun 29, 2016 | 07:59 PM
gkull's Avatar
gkull
A wheel should not flex, but to use my drag slicks I put in these 1/8th inch aluminum wheel spacers that i bought from summit racing for our bolt pattern size
Old Jun 29, 2016 | 08:34 PM
Gale Banks 80''s Avatar
Gale Banks 80'
For what its worth my 02 Silverado has about 2 Dimes worth of clearance with the factory stock Aluminum Wheels on it.
Old Jun 30, 2016 | 06:10 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I'd be worried if the wheel flexes enough for that to be an issue. You'll get plenty of warning (rubbing noise) if they do. I'd run them without spacers and see if it became an issue - and I'd expect it would be fine. Nice looking wheels!
Old Jun 30, 2016 | 07:44 AM
jb78L-82's Avatar
jb78L-82
I just put 1 year ago impala 12 inch rotors in place of the front 11 inch Grand Prix rotors with the stock GP rims and the clearance is VERY close...no issues after 15,000 miles of driving.
Old Jun 30, 2016 | 12:15 PM
76Rat's Avatar
76Rat
I recently installed the Street Lite Black rims on my 76. My front rims just touched on the caliper. I ended up putting 1/4" spacers on mine just to be safe.
Old Jun 30, 2016 | 12:29 PM
ddawson's Avatar
ddawson
That's a little too close for me. I'd add a 1/8 spacer.
Old Jun 30, 2016 | 01:59 PM
flyeri's Avatar
flyeri
That's about what I have, maybe a couple thousandths more. No issues.
Old Jun 30, 2016 | 05:06 PM
rajin cajin
Did you require longer lugs with the spacers?
Old Jul 1, 2016 | 10:09 AM
76Rat's Avatar
76Rat
I already changed and upgraded the rear studs to the 1/2" x 3"ARP studs when I installed the HD rear axles, so there was no problem there. I did end up changing the front studs, though. I wasn't comfortable with the amount of threads that the lug nut was catching. I'm running open lug nuts so I cut off the excess stud flush with the outer edge of the nut. I'm running the 7/16" x 3" ARP suds studs on the front.
Old Jul 1, 2016 | 10:51 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
As long as its not touching you're good. I wouldn't worry about that. I have raced on wheels with that much clearance.
To How much caliper clearance is needed??
