1976 tach filter
Old Jul 2, 2016 | 10:31 PM
76al's Avatar
76al
Cruising
Default 1976 tach filter
When i took the tach wire from fire wall out of plug (No Filter) and put it into The Dist cap,The tach works got a new tach filter wired up then put into filter nothing ,Put wire back into cap works but when you shut car off tach does not go to zero but if you turn key on no start goes to zero confused Do i need Filter thanks Help
Old Jul 3, 2016 | 02:16 PM
'75's Avatar
'75
When the key is off, the tach needle can settle anywhere, but goes to zero with key on. Seems like there is something wrong with the new filter, you should see no difference when it's inline but it protects the tach from hi voltage spikes.
Old Jul 3, 2016 | 06:11 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Original tachometer boards and our reproduction are made to hold the last signal received. So if you are idling at 700 when you turn off the key the tach should hold it pretty close. (aprox.. they still will drop depending on the condition of the analog movement). China made boards won't do this nor will the reproduction china tachometers.
Old Jul 4, 2016 | 09:31 AM
76al's Avatar
76al
Cruising
Just got new filter how can I check see if good thanks
Old Jul 4, 2016 | 09:32 AM
76al's Avatar
76al
Cruising
Original tach in car
Old Jul 4, 2016 | 10:54 AM
0Willcox Corvette
Former Vendor
If the tach works without it, plug up the filter and see if it works with it. You won't have what it takes to check the filter.
Willcox
Old Jul 5, 2016 | 08:52 AM
76al's Avatar
76al
Cruising
The tach did not work with the filter only without and the tach is steady when working what else could it be looked at what is intailed to take tach out ,not looking forward to that the new filter read 15.5 ohms old filter 16.5 ohms thanks for your wisdom and help al
Old Jul 5, 2016 | 10:30 AM
JimLentz's Avatar
JimLentz
Do you mean Kohms? 15.5 or 16.5 ohms sounds way too low. I assume you measured that from input to output, is that correct?
Old Jul 5, 2016 | 10:42 PM
76al's Avatar
76al
Cruising
Yes input to output on my multi meter measured at the 20 ohms thanks
Old Jul 6, 2016 | 09:42 AM
JimLentz's Avatar
JimLentz
Based on the schematic in this thread it should read around 15.6 Kohms.
Old Jul 8, 2016 | 07:21 AM
76al's Avatar
76al
Cruising
Default tach filter
Originally Posted by JimLentz
Based on the schematic in this thread it should reaod around 15.6 Kohms.
Can I run without tach filter ,when I did the tach worked normal no fluctuations ,not looking forward to taking out gauge cluster if it is the tach board thanks for your help
Old Jul 8, 2016 | 07:35 AM
JimLentz's Avatar
JimLentz
Yes, you can run the tach without the filter. Changing the tach board is a pain.
To 1976 tach filter
